Gday,
Just thought I'd post up some pics of my CAI setup I quickly hooked up today.
I'm going to make a box for it out of aluminium as in the tutorial section also but this is stage 1.
Pics-
1- pipe just hangin out
2- pipe at the bottom of the hole where the side mount cooler pipe would have been
3- the view including the air filter
4- the view from under the car.. zip ties are cool ok?
https://www.sau.com.au/forums/topic/52538-diy-cai-for-ceffy/
Second pipe - quite possibly will need removing cos it will get too hot but will see after some driving testing (of pipe temp and interference with other stuff in the engine bay.)
1- Pipe 2 sitting in front of the engine scooping air from under the car
2- Pipe 2 aimed at the side of the air filter
Ah - didn't realise you could do that.. Got any pics?
I got no room behind the plate cos of the intercooler.
It's funny though it makes my car look faster - I had an old man trying to flag me down to slow down when I was going down a street when testing it. Funny thing is I looked at my speedo I was 55km/h and about 1500rpm. heh.
Get some of that neoprene ducting from 'Revolution Racegear' - it is black and flexible :(
Are you in Vic or Sydney...?? b/c your plates are vic plates?
If you're in vic can also try Meridian Motorsport for the neoprene ducting - it is very tough and will no melt :)
I'm in Sydney. Plates are victorian cos thats where the car is from!
Neoprene.. hm how much is that? I'm using ducting designed for exhausting washing machine steam so I'll be keeping an eye on it. So far it's great but still keeping an eye on it.
here are some pics, its super easy, can spray it black or whatever, only prob is that I tend to find a bit more dust in the engine bay mostly around the filter. I think I will try and build a lid for my partician so it will just restrict it to the filter, will see how I go, got many projects I have to do.
yeah cc i dunno about that material man or its actual effectivness to move all the air to the pod... same with that neoprene stuff as it has groves and undulations which cause turbulance and friction.
the smoother and harder the material the better... im sure its still better than having nothing there tho!
Hmm - inark it's ducting.. It ducts air. It's not an exhaust manifold or inlet pipe. All it does is duct air into the car. While you're right about the turbulance and stuff but I don't think it practically effects it.
I mean the air the pod actually sucks in at any time is still there whether it's ducting pipe or straight pipe. Obviously the straight pipe is more effective but the ducting does enough to suffice.
Obviously all the above is from my own assumptions - it's not tested or from race research/experience so I could be wrong.
id say with more turbulance and a floppy material it would effect it... more turbulence the less flow the less flow the less air that gets thru to the pod as some form of blockage type affect would be caused by the turbulence... of course this is just one of my rediculous theories to help keep my brain active while doing a very boring and dull job :cheers:
best way to tell would be to make a solid one... get a high powered fan and sit in front of it and see how much air gets thru to the pod using either.
Hey thats a good test theory if I get one I will.. !! maybe even a hair dryer or something.
My assertion though is that the difference in the amount of air shouldn't affect it because either way is MORE than the pod will ever suck in at a time. Maybe I'm wrong here I dono.
i wonder if you got a battery powered fan from dick smith's electronics, you know, the ones that are shaped like a strawberry?
if you sticky taped that in front of your filter, then you'd have fan air induction, and girls would dig it like i make them dig my garden on sundays, while i play videogames.
Lol ! You know what’s better than a battery power fan from dick smiths... a solar power fan from dick smiths... get the solar panels on your bonnet, combine their power into one fan & create boost before it even reaches the POD. Turn your GtsT into a Twin Turbo :wassup:
PS: I've seen a electronic supercharger on some website which reates 2psi :P
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
