Hiya all. I've got a 97 rs4 auto putting 330hp at all fours (without NOS). t04b, 3" exhaust, stainless manifold, fmic, Greddy plenum, 90mm throttle body, 700cc injectors, adaptronic computer oh yeah it's auto too. Haven't put it on the dyno since getting Nos, But 100hp shot spun all fours up the street :):):D !
jesus h christ you better post up a video of that just to prove your not having a lend of us,
ps start a new thread and tell us how a adaptronic runs your auto and post photos in photos thread, by the way welcome to the club.
Hi guys. I'm not sure how to start a new thread. I forgot to say its a stock rb25det aswell. The adaptronic runs everything fine. Anthony from Kaizen Garage 0415 185 815 Brisbane did the install for the computer. he got the auto running with it aswell. Lochlan 999 automotive Brisbane did the tune. 18psi.
I'll have photos and dyno sheet up for you guys soon. I just want to get a good 1/4 mile time first. It's run a 13.8sec so far but there's still more in it yet!
  • 4 months later...
well its been a while but she is finally tuned. mods are full 3inch exhaust with highflow cat ,gcg highflow turbo, nistune piggyback, splitfire coils, cheap monsa ebay fmic, cheap electronic boost controller running 15 psi and z32 afm..
302hp at the rear wheels
not shure what that would equate to at all fours?
Edited by jippa
Good work! Have you got a AWD auto or 2wd manual? I take it you have a S2 (since you have a nistune chip). That figure would be very roughly equivalent to 200AWKW - a solid result but I would have hoped for more with your set up. Were your injectors approaching 100% duty cycle?
I have a GCG turbo (S1 so some stuffing around adding another ecu to enable it to be chipped) and expect around 200AWKW but I want to get the most out of the GCG turbo so am going to get 550 cc injectors to try to reach my goal of 220 - 230 AWKW - although anything on the right side of 200AWKW will make it pretty fast as you have no doubt found. Will be interested in your 1/4 mile time.
awd auto. the injectors are getting close to max duty.
i went for a mild tune as i dont want to destroy my engine and its my daily driver so still want some sort of economy. im also geting over pouring money into it which i wont be getting back.
so far im close to 5k spent on mods
No offence intended mate. . . But that all haha :whistling:. You had it long ? Nice dyno result though :D
No offence intended mate. . . But that all haha :P. You had it long ? Nice dyno result though :D
close to a year..
quater mile time was a 14.36 at 100.22 mph at 15 psi
she was misfiring quite badly so with a new set of plugs and slightly gaped down might make it into the 13s
I just realised I haven't posted in here
260RS
Vipec ECU running 13psi and ~11.6:1 up in the revs
3" Apexi front pipes, 5" cat, 3.5" cat back
263hp (196kw) at all 4. I haven't had a chance to take it to the drags yet. Would love to know what it'll do.
Itching to go the next step with new turbos, injectors, fuel pump and clutch, but we're building a house, so all mods are off :(
  • 1 month later...
I just had my stagea dynoed last week
The mods are:
3in exhaust
Hybrid FMIC
random highflow turbo
SAFC
RWD conversion
Stage 2 MV shift kit
Ended up with 182rwkw @ 13psi
It seems to have horrible midrange on the dyno though. AFR's are ok so I don't know what is causing it. The thing is on fullboost at about 2800 on the street so it doesn't seem lag related.
We did the dyno runs in 3rd gear with the 'red plug' detached in the engine bay auto loom. Perhaps the torque convertor doesn't like this?
How are other people running their Autos on the dyno to stop kickdown? 2nd gear maybe?
The mods are:
3in exhaust
Hybrid FMIC
SAFC
RWD conversion
Yep put it in 2nd gear and put the snow button on (locks out first gear). You need an Apexi SITC so that you can adjust the timing.
260RS
Itching to go the next step with new turbos, injectors, fuel pump and clutch, but we're building a house, so all mods are off :)
Thats interesting, when i first dynoed my 260 with the exhaust done it made 230rwkw? Now with a bit of work its making 313rwkw, still a few more things to finish off to hopefully see the 330 mark! :banana:
Let me know when you find one, I have been looking for 5 years without success.
Cheers
Gary
I've got a few ideas I'd like to try. I have an R34 GTT auto ECU here that I would like to give a go (with a Nistune board), but i'd prefer to get my hands on an S2 Stag ECU and rewire to suit then Nistune it.
Unfortunately I don't think this has been tried yet
I don't mind hacking my loom a bit. When I bought my car it had a Microtech MT10s in it and the loom was hacked to suit, so its already a bit of a mess.
Thats interesting, when i first dynoed my 260 with the exhaust done it made 230rwkw? Now with a bit of work its making 313rwkw, still a few more things to finish off to hopefully see the 330 mark! :thumbsup:
Yeah, like I said, it's tuned fairly conservatively, since it's our only car and my misses drives it to work every day.
313rwkw is pretty nice :banana: What have you done to it. It must be an absolute blast to drive. One day I'll get there....maybe :)
It might be worth PMing FastRotor on here. I believe he is running a Link G4 Plus(?) which is basically a Vipec and has knocked up some electronics to force the Vipec to switch to lower timing map on gear changes.
Way ahead of you on that one. I've been talking to FastRotor (Gary) since I bought the Stagea.
Vipec isn't really in my pricerange though. I will end up doing a remap of some sort I think. I just need to find out what option works best (or find an option that works at all!)
just booked in for my second every appearance on the rollers.... Very interested to see what it will do...
last time it made 155rwkw with splitfires, .8mm gapped plugs, safcII, FMIC and 12psi.
Since then ive done the following power mods:
3" turbo to gutted
Cat to 3 1/4 cat back
SITC
Reinforced intake pipe
Pod/box cold air feed
Any one wanna guess what im going to make?
313rwkw is pretty nice :) What have you done to it. It must be an absolute blast to drive. One day I'll get there....maybe :thumbsup:
Hmmm, well its just easier to say i havent done cams or coilpacks, everything else i have done..lol.
And yes its fun to drive, i still love the dazed and confused look on commodore drivers faces when a volvo leaves them for dead! lmao
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
