I've got a td06SH 25g 10cm on my 2b5 with stage one cams and no vct. Full boost is about 4000-4500rpm at 19-21psi (shitty gate spring) and get 320rwkw. it feels bit lag, specially when i snap second and the revs drop a fair bit.
Im thinking of changing to 8cm and also to e85, does anyone know if this is a worthwhile change? how much power and what rev range would i get full boost if i change????
  • 4 weeks later...
Thats a massive fail then.
The stock vct gear can be adjusted by removing it, and a mod available to adjust it from the front when still installed.
Being able to adjust it is in no way at all worth losing vct for.
Make vct work again.
^^ above comments are a bit of a blind alley. OP wants to know about the response capability of his turbo.
Andrew the spec you are running is broadly equivalent to a Garrett GT3576 in terms of impeller sizing and ballpark airflow capacity if not response/cost/durability. If it is an internally wastegated setup then it is possible your response may not be optimal compared to a reasonably well configured manifold/external gate.
Your figures are a bit rubbery to comment on, although the power figure of 320rwkW on petrol and 20psi is quite respectable (compares ok to a GT35 too).
On an RB25 with that turbo, if you made 20psi at 4000rpm you should be quite happy. If it takes until 4500rpm it's still not crappy but you'd hope for better.
However it is not a bottom-end response type turbo and I wouldn't expect much action under 3000. But it should be very strong across 4000-7500 or higher depending on the camshafts you've got. If there is an 8cm housing available it's likely to choke the thing up high, with maybe a 3-400rpm earlier spool. Not really a win-win,
Check out a TDO6SL2-20G 10cm, or the Hypergear version with their "20.5G" compressor. Sticking one of those on; fuelling with E85 should give about the same max power figure with a whole lot better bottom end response.
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
