  • Replies 47
I saw a Stagea run an 11, that's a fast boat.:)
Hi Have you towed any of the race cars yet with the Stagea?
Used your suggested suspension settings on my R33 track car's first outing....result very good, pretty neutral handling with good front end turn in. thanks :D
Good to hear, you need to fine tune the settings to your personal tastes, but it's a good place to start. As for Stagea towing, I haven't found a tow bar with enough capacity yet, still looking
  • 3 months later...
Yeh when is the Winton UAS day? Im in melbourne and will be trying to convince some of the hillbillies down here to make the trip north for the weekend...:(
Could get down there one day although more likely to go to Qld. Waiting for my custom trailer to be finished.
The boat is getting pumped even more. Found the valves were badly worn from too much boost and not enough valve spring pressure even though the springs were twice factoryspec. Now have Supertech .5mm oversized valves. Found Arias chrome rings not best for high temp and boost as they wore out, so going 40 thou oversized Ross pistons with full steel rings gas nitrided and proven in big boost drag cars. All cryogenic treated. Changing turbo's from S15 to Disco potato GT28RS 440hp each. Getting the exh housings high temp HPC coated and if have time will get comp housings extrusion honed. Should make 450rwkw with if anything a little more lag which won't hurt it. Might even get semi slicks on to keep things more honnest hey FATZ?
  • 4 weeks later...
Next UAS track Sunday 1st May Wakefield and keep your eyes on your mirrors please.
Roy Porsche 6 piston GT3 Carrear cup Monoblock's lightwieght, brand new can do $800 each. Second hand $650 each. I know you would use them.
  • 3 weeks later...
Put new motor in and new D2 suspension and went to Nissan Datsun Nationals Easter Sunday at Wakefield. Only got three runs on the full circuit and only managed a 1 min 9.48 although still fastest car on the day next fasted was a Dato 120y coupe FJ20 near 200rwkw 900kg 2 seconds slower. Heaps of zeds and a few Skylines and a R32 GTR. Got back and pulled motor out Tuesday to remove turbo's to get extrude honed and high temp coated and a few other minor changes then going back in next few weeks ready for our track day. Bring on your GTR's or GTS-T's.
PS more GTR parts as now has GTR bronze valve guides and valve stem seals. We measured and found the valve guides to be slightly shorter and protrude less into the ports so less restriction and proven on flow bench test.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
