Hey guys, i got my suspension i ordered through nengun today, the TEIN type wagon. only problem was when i opened the box, there were only 3 shock absorbers, the 2 fronts and only 1 rear.
I think this is a funny sort of suspension kit, considering what i paid for it.
as soon as they send me the other shock absorber i'll let you guys know how it fits, for now here's a pic of the 3 i have.
Post up the measurements (wire ID, coil ID and the number of coils) and I will work out the spring rate for you:cheers:
Well Nengun say they sent the 4th shock in a previous package, but with the same EMS number. My post office said they haven't received another package with that number, so idon't know where it is. hopefully it'll show up somewhere, it has my name and address on it, that should help it find me.
So they sent a single shocky first by itself, then sent 3 more... LOL - wtf??
Posted this elsewhere but should probably go in the suspension thread for people looking only in here for supension options...
Here's an dam expensive choice at $3700 - but very noice being PentRoof Bilstein WGNC34 specific coil-overs :D
order online from: http://www.ab-flug.co.jp/indexf.htm
(and shout me a set while you're at it)
Here's an dam expensive choice at $3700 - but very noice being PentRoof Bilstein WGNC34 specific coil-overs :cheers:
They won't fit a Stagea (non 260RS), they have forks at the bottom of the rear shocks, Stagea rear shocks have eyes at the bottom. They are GTR shocks I would say.:)
Awww - dammit
Thanks SK... spoilsport
Do all the parts on my other thread look like 260RS only parts SK??
Cheers
They state 7/6 which is 7 kg / mm (390 lbs per inch) for the front and 6 kg / mm for the rear (335 lbs per inch).  As a comparison, the standard Stagea fronts are 165 lbs per inch, so that's a 137% increase in spring rate.  Usually for sporty road use I would be loooking for around 30% increase.  I think I'll leave it at that, you can make your own judgement from the numbers:cheers:
Call me stupid SK - but I cant get my head around this - didnt really think about it when you did this reply above, but...
If 7/6 is around a 137% increase and way too hard, and 30% increase is ideal ... arent the Tein S Tech springs ok, being 3.1 Front (172pounds/inch or 4% increase over stock) and 3.8 Rear (213pnds/inch or 25% over stock).
The Tein S Tech lowering springs would end up under the 30% max you recommended, with 25% increase at the rear, and pretty much same stiffness at front with only a 4% increase.... but you have said before the Tein spring are way too stiff.... am I still missing something in all this suspension mumbo jumbo??? :confused:
Cheers
Hello all (esp SK)
Time to replace the radius rod bushes on the stag. Do I go factory or
do I go whiteline ?? if they have them
And while I'm at it, should I get a more "adjustable" setup in the radius
rod setup ??
Any hints clues would be appreciated
cheers all, and thanks, this is a great forum !!
Cheers
Nope, you got it right, if the Tein S Tech are truly 3.1/3.8. Maybe they started to listen to the rest of the world. Then it's down to what shock valving rates they are using.
Hello all (esp SK)
rod setup ??
Stageas (like GTR's) need more caster real bad, so I would always go for the adjustable Whiteline replacement bushes. Being 4wd, we can't get as much caster on them as GTST's, but every little bit helps.
Looking for some input guys (esp SK).
Getting the radius rods replaced (bushes are shot) on Wed, and the guy said I can have the adjustable versions if I want. Is this a better option than the whiteline bushes (both will give caster adjustment ??). Or do I completely misunderstand
the Stagea front suspension ?
thanks and cheers
thanks and cheers
Previous post on this subject......
In order to increase the caster you simply pull the front wheels forward in the guards. Not enough to rub though. This changes the front steering toe angles and therefore you need to re-align it after fitting and adjusting the caster.
If the caster rods you are looking at have spherical joints at the front (not polyurethane or rubber) then you will notice a slight increase in NVH as there is no dampening. Sphericals also wear rapidly on Australian (rough) roads, and they then knock noticeably.
Since they don't have as much "play" as a polyurethane bush they do provide more constant caster settings (less flex) but that comes at the price as above ie; as usual, you don't get something for nothing.
As you can tell, I am not a fan of sphericals in a road car, they wear out very fast in that environment, knock like a bustard and cost as much as a new arm to replace. Plus they add quite a bit to the NVH (noise, vibration & harshness) even when new. Consequently I would always recommend an adjustable polyurethane bush.
:rofl:
SK, your'e a legend, thanks heaps for the info.
Just to let people know, i'm getting my TEIN Type wagon coil overs and whiteline sway bars installed tomorrow, i'll get some pics up once i get her home. i don't have time or tools to do it myself, which is a bummer because this thread is super helpful.
anywho, just letting people know if they're interested
Cool, it'll be good to see how it goes. Once done you'll be able to out handle most cars :D
I've been tempted to get a set of sway bars, but I know if i get them then I'll want new suspension and then do the camber and next thing i know I'll get a loan and do a rb26 and 5 speed converstion.. lol
Well got my car back from Inline. he says the springs have to settle before he can lower it at all, but the sway bars are in and work absolutely awesome. the car takes corners like it wasn't even trying, and there's barely any body roll. all in all a good investment in my opinion.
The Bilsteins go in this weekend, so I measured the centre of wheel to guard heights as it is now;
RHS Front 395mm
RHS Rear 370 mm
LHS Front 395mm
LHS Rear 372 mm
I am thinking of around 360 rear and 370 front, so I will have to machine some extra circlip grooves.  Maybe 6  at  5mm intervals.
Need some feedback from the guys that have already lowered theirs, please post up your centre of wheel to guard heights...........:cheers:
SK,
I realise this is an old post but have just measured the S2, and the figures are:
RHF 360mm,
LHF 360mm,
RHR 365mm, and
LHR 372mm.
However I have a weeping shock on LHR so may be this is having an impact on height.
The vehicle has NISMO springs but have no idea as to what the specs are.
Marc2
SK,
RHF 360mm,
LHF 360mm,
RHR 365mm, and
LHR 372mm.
Marc2
Thanks Marc, looks like the usual 30 mm lowering on the front, but with standard height rear. I did similar with ours, it takes away that nose up look they have when the rear springs settle due to load carrying. The diff right/left rear is usually because they spend a lot of their life with just the driver in the car. If you are changing shocks it may pay to check the free height of the springs and maybe swap left to right.:cheers:
PS; send me the spring specs and I can rate them if you like, using the computer spring rate simulator, it is very accurate. I would need the wire diameter, coil ID and number of coils.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
