Ah, now THAT looks more like it... good spotting :D But does it fit? Is it the right length etc? Basically need someone to be a guinea pig and try it out ;)
They (Whiteline) do call the KTA117 a "Rear upper control arm", and the application listing lists the R33 and R34, so that makes the 117 sound more appropriate for the job... but it doesn't have the bend. So either might work... if the 128 doesn't fit then maybe you could exchange it for the 117.
Another member (think it was 'rb') had a bad experience with KTA118 and was told by the suspension shop that there was no bushed-style control arm available from whiteline for stagea rear camber... but it would appear that you've found two good possibilities there.
Cool thanks, didn't see them. But they're not a bushed type setup are they? And they seem to be fairly close in price to a pair of KTA117/KTA128 (although I haven't verified that yet - waiting for someone to get back to me, hopefully around $200-250 delivered).
no bushes with them so they will need attention but cheaper than new tyres.
i picked up a set of similar type for $100 or so and they seem to be going fine over 12mths but no doubt they may get noisy in the future and may need attention.
if you get a bushed version it will be interesting to see how they go. they should prove to be the best solution if the price is right.
Ah, now THAT looks more like it... good spotting :thumbsup: But does it fit? Is it the right length etc? Basically need someone to be a guinea pig and try it out :ermm:
"Believe half of what you see, and nothing of what you hear!" as the KTA128's look like they should do the business
I haven't had my car in for an alignment (crazy festive season) since fitting the offset bushes, but I can say that visually, the rear tires appear to be nice and square
As always, I will share my experience when alignment is performed
richard
cheers Richard, I'm interested to see if you can get rid of enough negative camber with the bushes. Could you remind me again, do you have a series 1 or 2? It seems to be the series 2's that show too much negative camber?
richard what are these offset bushes you talk of? do they fix the neg camber after you have lowered the car? what do they do for the toe?
To fix the camber issues I need to get adjustable camber arms and toe arms correct? I was thinking Id get isc's cos you can get both for $338.
need to work out what im going to do about camber as im getting new tyres and wheels soon and dont want to chew out the inside edges to quickly :S
my KTA128's get here tomorrow afternoon and will be going straight in. i originaly purchased superpro camber bushes for the rear but could not be assed pulling the hub out to install the outer bushes ($330 inc gst). Kidafa, i am getting my arms from cartorque on north tce at kent town, have used them before and recommend them.
i fitted a set of eccentric bushes and they don't go close to enough adjustment on a S2 stagea (but they were fine for my R33).
the camber arms were the only way to get enough adjustment for my purposes. btw this is with a 370mm wheel to arch rear height so not low at all.
Edited by wolverine
Ahh, so we have a guinea pig. Let us know how they go. What did you pay for the KTA128's?
Exactly the situation I was afraid of... I'm out of max rear factory adjustment and STILL -1.5mm (too much!) at ~395mm. 370 would not be low at all.
fitted like a dream! :D easy as to install and heaps of adjustment. might paint them black for that stealth look though :laugh: . getting new tyres and a alignment firs up in the morning. they cost $290ish inc.
That is great stuff. Great stuff! Series 1 or 2? Not that it matters really (should fit both?), just wondering. So rear camber problems solved; price not toooo bad... I might have to call Cartorque next week.
s1 and s2 are the same. my hight at the rear is 360mm and my aligner set the rears at -0.5 each and still had heaps of adjustment. highly recommended. didnt have them in stock, had them freighted in overnight.
Excellent
Series 1 - 350mm wheel centre to guard
Super Poly Pro , Remove some neg camber , I believe that it increases toe in, as it pushes the top of the tyre out
Offset bushes will only remove so much
The bushes can be removed with a two-leg puller without removing the hub
richard
Edited by rb
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
