How wide are your rims? Excessively wide rims will not help your roadholding. I have 17 x 9 (with 255 40 17 tyres) and use 15mm spacers to clear the shocks and have pushed out the guards a little. My shocks are Bilsteins with Tein Springs which are about 20% harder than stock. My ride height is 340 front and 330 rear. You can use BC coilovers. If your rims are getting in the way of some good suspension change them. My rear sway bar is the BNR11XX 24mm. When I track my car I have 17 x 8.5in rims with slicks.
. Sorry! i can't edit my posts. My
I've read about 30+ pages and scoured the Internet for a few weeks and I can't find a definitive answer.
I don't think i can use aftermarket coilovers as i only have a cm of clearance from the stock shock to the rim and i have a cm of poke so i can't use spacers.
What lowered springs fit the standard stagea shocks?
I've read a few threads where people say that 33gtr front springs and 33gtst rear springs fit the standard stagea shocks. But from reading these posts it seems as though they're confusing springs with shocks with coilovers, as everyone has said the 33gtst rears have a larger top hat. So in theory the springs will not fit the standard stagea shock?
The stock stagea spring rates are Front - 2.9 & Rear - 3.1 Most aftermarket spring rates are in the mid 3's F&R So this should compensate for the heavier rear end?
Please i really need some help as information is scarce!
I would like to track the car, but it will probably never happen, most of my driving is at the posted 70kph with plenty of round abouts and sharp corners, I like the car to feel less boaty (rims made a huge difference), this is my reason for harder lower springs and sway bars. Just coilovers wont give as good of an upgrade, is this correct?
I've tried to give as much information as possible.
I've also emailed a few companies but have not received any replies.
My rims are 9.5" wide on the rear with 245/35/19.
I measured the clearance: 15mm rim to shock. 10mm shock collar to tyre. 5mm poke.
ride height: 400 front. 370 rear.
The handling from 19" rims was outstanding, coming from 225/50/16 & 205/55/16 with 32 & 36 & 38 & 40psi. I've tried a few combos ha. and would like to keep these rims.
I could use some 10mm spacers, but once BC's are lowered the spring would hit the tyre wouldn't it?
Do you know the code off your teins? Their website doesn't list any springs for the skyline or stagea.
Thank you again Bob you've been a big help with things!
I have Tein "S" tech
Front Tein F-SIN78-101311-HCC
Rear Tein R-SIN79-010382-HCC
Shocks are labelled "Nismo" but are actually made by Bilstein
Front Nismo 56110-RSC45 ENP
Rear Nismo 53210-RSC 45 ENP
If you have 245 tyres (narrower than mine!) you only need 8 or 8.5in rims - the extra width won't be helping but just get in the way.
This is a picture from adams rear tein coilovers. Judging from the shock length and cir clips, it should lower my stag 2-3" before the cir clip will touch the tyre. What do you think?
Yeah i know the rims are quite large form the rear, but they look amazing and i got them for a good price. I'm not willing to sell and buy new rims atm
LOL I'm an idiot, no way they're fitting in the rear.
Found a thread from '08 everyone agreed that
gtr33 springs fit the front & 33gtst springs fit the rear. I'm guessing the is for an rs4s?
Found another thread from the whiteline group buy
34gtr spring fit the front & 32gtr springs fit the rear. I'm guessing this is for an rs4 S1?
I don't like wasting money buying things and finding out they don't work.
Any help is greatly appreciated.
Mine where put together by EVO R in Perth they are std coilovers. From what I remb it was 32/33 gtr tops and lower for the front and s15 tops with 33 gtst lower for the rear. But not 100% on that.
Btw think u might beable to undo the lower part of the coilover to adjust the length
S15 tops with 33 bottoms for the rear?
Couldn't I use my stagea std tops on 33 rear bottoms?
Info from king springs and this thread:
Front:
Kdfl101sp - 380mm - 175lb - 3.125kg
Kdfl101 - 360mm - 1st Inch 135 inch pound, remaining 180 Inch Pound
Rear:
Kdrs87 - 360mm - 195lb - 3.48kg
Kdrl102 - lower than kdrs87 - 155lb
Kdfl101sp & kdfl101 & kdrs87 has been used buy an awd stagea owner/customer of kings, and these are the measurements taken.
I have bought a brand new 24mm rear swaybar kit and a 22mm front swaybar for very cheap.
This should stop any camber/shock rubbing issues with hard cornering. Eventually I will get a stock front stagea strut brace to use in the rear.
Kdfl101sp and kdrs87 are the springs I will be using. Unsure how it will handle with .32 harder springs in the rear as most people use softer rears.
Is there anything anyone would like to add? Or disagree with?
King springs are usually $120-150 to your door for a set. Cusco $140 from jap unsure on shipping probs $300 all up, stagea front $60-$100 to your door, and it matches the front with the sticker ha.
Do you know if I could use my std tops on 33 bottoms? I've never seen either of them out of the car, I can't see why not?
Why don't you think I should bother with kings? I know you can get teins that are $330 to door and front - 4.2kg. Rear - 3.6kg. I think these would be a lil stiff for the standard shocks and would bounce a lot. What do you think?
How low was your vl? What's shocks were used? What condition? What were the spring rates? What other mods did you have?
A friend had a vs with ssl with shortened Monroe gas all brand new and it was bouncy and would thump on large bumps. While I had an ef with 2" lowered lovells with shortened kyb shocks that were a package and that was very comfy yet firm and handled well. Bushes played a large roll in this, and rim/tyre size too.
I'm far from an expert in suspension, but I believe the shocks need to match the springs for a good yet comfy ride. That's why I'm leaning towards kings as they're 0.2 heavier in the front and 0.7 heavier in the rear.
The stagea is 200kg heavier than a 33gtst. And that's not 200kg of weight in just the rear, that would be in the front suspension/diff, electric seats, gearbox, rear glass, sound deadening. I would say the stagea is only 50-100kg heavier in the rear than a 33gtst as a 33gtr is 100kg heavier than a 33gtst.
This is why I think 33gtst shocks will work fine in the rear. It's like having a family or car pooling. I do neither.
Does anyone here had experience with Jamex Super Lows Springs? I read alot of conflicting reviews about them. Are they any good? or just waste of money.
I remember reading something about them (perhaps in this thread somewhere), but i would also like to know other opinions..
Got it all sorted now, i got recommended to see the guys at Light Suspention and wheel alignment. Only cost $90.
10kg springs in the front with -1 degree camber, 8kg springs in the rear with -1 degree camber.
The car now drives like a dream, it just needs bigger sway bars and it'll be sweet.
Does anyone know the part number for M35 stagea front lower ball joint?
I've brought a set from here: http://www.ebay.com.au/itm/250697175942?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_827wt_1163
put it in and there is lots of movement after the install. I've notice that the ball joint i've got is missing a "cap" that the original have on top of the rubber.
Any suggestion?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
