Hello,
My car was on a dyno yesterday and apperantly it started to ping. After a clean of the injectors it luckily pinged no longer (I wonder for how long).
The problem I do have is that it was (apperantly) close to leaning out. If I want to up the boost I run the danger of killing the engine/turbo.
My question is what sort of things will I need to check (incase they need fixing or upgrading) so I can safely run that sort of power level?
I realise a few things such as checking the fuel pump pressure and maybe upgrading the injectors are two things that need to be checked/upgraded.
Before I go to the shop and start getting bent over I'd like to know what I should get checked/think about to get more fuel into the engine?
If anyone's interested dyno sheets attached.
Thanks guys.
So your making that sort of power and haven't upgraded your fuel pump yet? :)
Your living dangerously if thats the case.. All it takes is for the pump to start slowing down just a little and you will find your self replacing the motor :P
I thought the fuel pump was upgraded to something beefier (GTR item perhaps). I'll have to ask the previous owner again.
I was 99% it was cos you can hear it at the back of the car whirring away when the car is on.
So.. I'll add that item number 1 - Check fuel pump pressure. Thanks Joel :P
Adjustable fuel reg sits between the engine and fuel pump right? So you have a fuel pump that pumps a bit harder than usual then the fuel reg "holds" it back a little so you've always got the same fuel rate?
Zat right?
Zat right?
A fuel reg limits the amount of fuel returning to the petrol tank.. In turn raising or lowering fuel pressure. :P
Ahh. Thanks Joel.
Is there anything else I should check? Could it be the timing is too advanced? They said they can retard it a bit and that should be ok too.. less power but less danger of pinging.
So other than checking the fuel pressure, the timing, fitting a fuel reg, possibly bigger injectors what else should I do if I want to run more boost?
It really depends what the tuner thinks..
If you are running out of fuel rail pressure then its the fuel pump.
If you have simply maxed out the duty cycle then you need more fuel pressure or larger injectors to use the potential of the turbo.
What turbo are you running?
That is the deciding factor for if you should jump in and go for larger injectors or to spend the $$ on a fuel pressure reg to squeeze a little bit more out of the current injectors.
tom the fuel pump is a walbro (255 litersd per hour I believe. was brand new whn the motor was fitted) the car is leaning out if under boost its is reading 12.5 or higher on the a/f ratios how much boost were you running or was it just as is.
the car doesnt seem to be running higher than 12 when under boost.
you will find the fuel map pretty linear even when the boost is up no need for bigger injectors as the car has 550 cc injectors. the injectors were cleaned and serviced when the motor was put in this car.
cheers
steve
call if you have any other questions
Ahh. Thanks Joel.
Fuel pump and injectors have been upgraded. I believe they are 550cc injectors and walbro fuel pump.
Turbo is Greddy t518z - rated for about 250kw i think?
I'm not sure anymore. Maybe I should have the timing retarded a tad?
Say 550cc injectors will support 550hp on a 6cyl RB..
Thats roughly 91hp per injector.
If its an SR20 then 91hp per injector x 4cyls = 364hp.
200rwkw = 268rwhp which is approx 340-350hp at the flywheel.
I'd say 200rwkw is pretty close to the limit of the 550cc injectors.
if you have upgraded the injectors and fuel pump you have already had the stock computer remapped or you are running an aftermarket ecu. this being the case you should be able to correct the a/f ratios with a remap...
your power curve is nice.
need more details on the ecu dude... :rofl:
The ceffy is running a remapped ecu, z32 afm, 550 cc injectors, and walbro 255 lt/hr pump.... It was tuned for mobil 8000 in Melbourne, maybe your running different fuel that could cause the light pinging?
As for running lean down low this is not a problem, as a matter of fact it's caused by running of the factory o2 sensor until it reaches a cerain afm voltage and then goes onto the correction maps.
We had this map running up to 1.4 bar reliably.
Feel free to pm me or call on 0425 818 755 if you ever have any questions about this car.
Doc.
Thanks for the reply guys.
The topic is a bit mis-leading actually- the pinging stopped after an injector clean. They suggested maybe turning the base timing down a little too but I didn't wanna mess with anything just yet.
The dyno sheet says SR20DET is that correct?
Yes that is correct.
Interesting point you raise Joel. I always thought 550cc were more than I'd ever need. I will investigate this further - thanks for the heads up.
Dr what's your opinion on this? Should I be looking at bigger injectors?
The ECU is dr_drift's doing - so maybe you should ask him in this thread? (save the middle man ie. me).
Thanks for the info. I was using BP Ultimate, about 50/50 from different fills but both BP Ultimate - in theory should be 98RON and wasn't sitting in the petrol tank for too long (couple of days).
The standard o2 sensor plug is disconnected. Meggala said there was another one instead so I assume the old plug was just disconnected and doesn't attach to anything, leaving the other o2 sensor and wiring to do the work back to the computer. Does that sound about right?
If I wanted to up the boost dr_drift is it just a case of putting in an EBC and whacking it on a dyno and the computer should do the rest right? Because the guys at UAS seemed to think it was on the borderline of running lean and with any more boost on it wouldn't be good. On the other hand they didn't know the computer would adjust for that - so if it does well then thats fine.
Should I be looking at bigger injectors then to be on the safe side? What would I have to do to make the AFR say 11.5 just to be safe? Or am I just being paranoid?
Thanks again for your help guys.
Stopped pinging after clean - one of them must've had some crap in it then...
If the car does ping definately remove 1 or 2 degrees base timing for safety.
12.0 is on the rich side, i tuned it a little richer to Meggala's request. The 550's should be fine for 220-230 with comfort tuned as is. Wouldn't bother with the expense of a EBC, try using a GFB atomic, that worked quite well with no boost spike previously.
If your after more than that I'd suggest replacing the walbro pump with something a bit bigger like the Nippon Denso 280 lt/hr, and upping the injectors to 740cc
The O2 sensor should be plugged in? Are you sure their not cinfusing it with the cat temp sensor? the O2 is at the top of the dump pipe.
Doc.
I'll get it dyno'ed again after changing oil filter, oil, fuel filter, sparkies. Hopefully the injectors stay clean and see how we go.
Yep the o2 sensor is plugged in on that side into the dump pipe. The plug they were referring to (which they thought was the o2 sensor) was on the top right hand side of the engine bay as you're lookin at it from the front of the car. Grey plug with a few pins in it - the plug is prolly about 1x1.5cm. I will take a pic when I get home I don't think it matters too much though since it is unplugged and when it was plugged in didn't make any difference on the dyno.
About when would I be maxing out the 550's and puel pump? Any point in getting a fuel reg to be safe?
The Dr has given you good advice. 12:1 AFR is certainly nothing to worry about. I have 2 maps on my re-mapped ecu and the 'aggressive' map runs an AFR of 12.4:1 with NO detonation/pinging.
Richard
Thanks for the reply mmm.
It was probably my injectors. I'm just scared of them getting blocked again. Hmm.
Cos my next upgrade was going to be EBC + cams and I didn't wanna add one thing to the mix and **** everything else up in the process.
It was probably my injectors. I'm just scared of them getting blocked again. Hmm..
Use a good fuel filter and change it often and you won't have to wory about getting blocked injectors.:P
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
