As topic suggest's, i've got a Wolf 3D V4 pro for my FJ, and my brother just had one installed on his FJ as well, only snag with it was that the wolf doesn't work with the standard TPS as its only an on off switch not a true TPS sensor...Now does anyone know if there is one that you can get off another motor (SR?? CA??) that will bolt up or is it easier to just swap to an XF throttle body at this stage and have one less restriction??? If thats the case, how hard is the XF throttle body to install?? Any cutting and shutting of plenum needed???
Cheers,
Shane
https://www.sau.com.au/forums/topic/53203-fj20-tpsthrottle-body/
Will it work with the Wolf though Ben?? Arnt the stock FJ throttle bodies fairly restrictive though when u start making some serioius power??? Bare in mind my turbo is good for upto 30psi and 450PS....
If I go programmable it will probably be a Microleb purely so I can junk the flap air flow meter easily. A friend is going to make up some plugs to make it a plug in proposition, and I'll be running a gutted RB30E airflow meter with wires going into the firewall to make it look like its standard, and the ecu will be in a Nissan ecu case.
Stealth :D
If you want something really unique why not use an SR20DET loom and Apexi PFC . That way you can get direct fire ignition and a choise of MAF's ie Q45 from Infinity .
Funnily enough, thats something that me and my mates discussed at one stage, it could be done, no reason why it couldn't just be easier to use a normal aftermarket ecu...
Adam i was looking at the microleb, but for what i got this wolf for really couldn't complain hehehe
My throttle body is from an FJ20E and was auto.It has 2 tps plugs on it for the auto trans.The second plug is the variable type tps that you need.Maybe some other factoy TBs from automatics will fit.The XF TB is a cut and shut job.My engine is close to 400bhp and it poses no prob(im also using wolf ecu)
Thanks Todd i was kinda waiting to get an answer from you about this!! Seems i'll have to go and suss an automatic FJ tps then hey!!
I was just throwing the idea of the XF throttle body around as an aside issue, i would prefer to keep FJ tb at this stage, and hopefully i can suss something to fit it!!
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
