I would be a bit worried about that car…
Look at the last two photos around the spare wheel. Are there cracks!? I think so!
I believe it's an accident car- the shell may have only done 24k but the engine looks older and "cracks" in the boot.
Good luck to the buyer.
  • Replies 93
Im with Steve also.
And like i said, the fact that paint from the plenum is peeling does not automatically mean the car as a) had a hard life or B) had its odometer tampered with
And for those commenting on how the engine looks "tired" and dirty which is apparently an indication of its true age or condition, you have got to be kidding.
Not everyone cleans and washes their engine bays. The climate and conditions in japan would also be a major factor in the surface condition of parts in the engine bay and around the car.
Blitz: how many kms did your 33GTR have? Was the plenum like that ?
I admit that I dont have any experience with GTR like you, do all GTR engine look like that after 24k kms ?
My car had 40,000 km's when I bought it and the paint on the plenum and rocker covers was perfect
I think it looks pretty good FOR THE MONEY! But if you look closely, you will notice the plug cover has been off the engine for some time - it does not have the soem level of oxidisation as the cam and timing belt covers.
I'd have it for that money! i bought my GTR from Geoff and it was in better condition than descirbed.
NAman - I don't think it has cracks in the boot - doesen't look accident damaged to me!
I think the buyer has done well!
at least its stock... even has the STOCK MUFFLER! i have only ever seen one of them in real life on a friends car..
as if its not wound back lol.
also the rubber around the gearlever isnt cracked (on most cars its cracked) and the front lip looks like its in one peice..
but it is missing the snorkle for the air box..
cheap either way but it is still risky(gtr repair labour costs) u never know about its mechanical condition till its here..
I'm beginning to think this one may have had slight water damage.... during a typoon or something. I wonder what the interior smells like?
You probably wouldn't have the time (or the desire to get involved), but it seems there's a business opportunity here for the guys like you in Japan - you could offer an independent inspection service for cars like this. Don't really need to be a mechanic, just check the cars out so they match description, all damage (if any) as described, etc etc, offer a general opinion - no guarantee's, of course, just the opinion.
Just a thought :D
Ok... I'll see what I can do about this guys. I add something to my sig if it's something viable for me to get into.
Just remember that I can only check cars on Sundays only and in Osaka city or Kobe only.
My whale has almost 96k on the clock when I bought it over and the paint on the plenum and the cam cover are perfect. Even on the pipe where it says "twin turbo" doesn't have white deposits on it either. I don't think the paint and the white bits are a good indication of the engine...
33 GTR with 24000 on the clock going for 1.5mil Yen - doesnt happen. Just for the record - my GTR (r32 sold to Kier Wilson) had 800000km on the clock, my engine bay looked a lot better. And for the roads in Hokkaido - yes they do salt them but this is not the cause of the "irregularities" of this engine bay. One of my suppliers is just outside Sapporo where they do salt the roads.
Nuf said.
Ken
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
