f*k thats freaky ... l live in Keysy, hope he does turn up to a meet, could do some "mirror" like shots with his car and mine!! :lol:
lol @ yelling out ... i'll look normal yelling out @ noble, enough other freaks there!!
Edited by [ STAGEN ]
spotted a series 1 stagea in wine red today on boas road in joondalup was having lunch at kulchas when it went past was heading towards grand bvd. looked stock from the side didnt see the plates tho. I thik it was about 12:30 ish
Spotted emmanuel's old beast on Saturday around midday, waiting to turn right on to Newmarket rd at wilston, right near the old gympie rd end.
I was on my way to pickup my beast from Mercury Motorsport, which I now have back, THANK GOD!
Spotted White S1 Stagea. 18's :) Nice nice, out at Moonbi
silver 97 s1 on mt tamborine stocker but has tv that dont work. the small brackets on the roof of mine are ror tv aerialsto mount. in the cargo section he had a large fitted plastic mat imprinted "stagea" similar to one i have in a forrester (worst vehicle i ever bought new}
anyone know where to get cargo mat?
AMS, the pearl white S1 you saw was mine! No doubt you've spotted it around Tamworth. Needs some mods done (full kit is my first priority), just need the cash to do it...
Dellie
Hey Adele,
welcome to the forums.
If you're free, a Stagea gathering is being organised for Saturday 22 April, details are here...
Feel free to join us!
Cheers,
Nick
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
