f*k thats freaky ... l live in Keysy, hope he does turn up to a meet, could do some "mirror" like shots with his car and mine!! :lol:
lol @ yelling out ... i'll look normal yelling out @ noble, enough other freaks there!!
Edited by [ STAGEN ]
spotted a series 1 stagea in wine red today on boas road in joondalup was having lunch at kulchas when it went past was heading towards grand bvd. looked stock from the side didnt see the plates tho. I thik it was about 12:30 ish
Spotted emmanuel's old beast on Saturday around midday, waiting to turn right on to Newmarket rd at wilston, right near the old gympie rd end.
I was on my way to pickup my beast from Mercury Motorsport, which I now have back, THANK GOD!
Spotted White S1 Stagea. 18's :) Nice nice, out at Moonbi
silver 97 s1 on mt tamborine stocker but has tv that dont work. the small brackets on the roof of mine are ror tv aerialsto mount. in the cargo section he had a large fitted plastic mat imprinted "stagea" similar to one i have in a forrester (worst vehicle i ever bought new}
anyone know where to get cargo mat?
AMS, the pearl white S1 you saw was mine! No doubt you've spotted it around Tamworth. Needs some mods done (full kit is my first priority), just need the cash to do it...
Dellie
Hey Adele,
welcome to the forums.
If you're free, a Stagea gathering is being organised for Saturday 22 April, details are here...
Feel free to join us!
Cheers,
Nick
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
