f*k thats freaky ... l live in Keysy, hope he does turn up to a meet, could do some "mirror" like shots with his car and mine!! :lol:
lol @ yelling out ... i'll look normal yelling out @ noble, enough other freaks there!!
Edited by [ STAGEN ]
spotted a series 1 stagea in wine red today on boas road in joondalup was having lunch at kulchas when it went past was heading towards grand bvd. looked stock from the side didnt see the plates tho. I thik it was about 12:30 ish
Spotted emmanuel's old beast on Saturday around midday, waiting to turn right on to Newmarket rd at wilston, right near the old gympie rd end.
I was on my way to pickup my beast from Mercury Motorsport, which I now have back, THANK GOD!
Spotted White S1 Stagea. 18's :) Nice nice, out at Moonbi
silver 97 s1 on mt tamborine stocker but has tv that dont work. the small brackets on the roof of mine are ror tv aerialsto mount. in the cargo section he had a large fitted plastic mat imprinted "stagea" similar to one i have in a forrester (worst vehicle i ever bought new}
anyone know where to get cargo mat?
AMS, the pearl white S1 you saw was mine! No doubt you've spotted it around Tamworth. Needs some mods done (full kit is my first priority), just need the cash to do it...
Dellie
Hey Adele,
welcome to the forums.
If you're free, a Stagea gathering is being organised for Saturday 22 April, details are here...
Feel free to join us!
Cheers,
Nick
