' date='25 May 2006, 04:20 PM' post='2201322']
wanna buy my wheels??? :)
haven't seen that pic before either. Car could be coming to sydney for Final Battle Autosalon too.
What new wheels you looking at man? That thing would be perfect with a new front bar! I 'think' I will be going in Autosalon Newcastle - havnt decided yet though
Spotted a Bayside Blue S2 just off Swan Street in Richmond last night around 11pm, Ian was that you? That's my first spot outside of Auto Salon, was pretty excited had to rub my eyes a couple of times to make sure it was really there! We were parked on the opposite side of the road, in the Commodore though... Would have been classic to have 2 Stagea's parked in the same street, need to get my alarm installed so I can remove the 5K theft excess! :)
Cheers
Luke
well if it were a s2 then unfortunately was not me...
although i have been on Swan st a couple of times this week and weekend.
OHH spotted a white S1 this morning on the way to work Corner Burwood Hwy and Springvale Rd....
though it was Alex as it was identical to his although i was wrong.... unless alex lent his car out??
Time: 09:54am
Place: Caloundra Turn Off
Direction: North on the Bruce Hwy
Car:Green S1
Identity: Qikstagea - I think.
I was heading South at the time (yellow S2) and I dont think the driver looked over. I tried to flash the lights but we had almost passed by then. What really freaked me out was that as soon as I saw the Stagea from a distance I said to the wife - there's qikstagea - didnt even have to think about it...I must be on this forum too much as I have only ever seen one picture of his car.
Spotted a Pearl White Stagea (s1) parked in Macquarie Street in Parramatta (NSW) this afternoon. I was on the way home from work, keeping my eyes open for traffic and kamakaze pedestrians, so by the time I realised what it was, it was too late for me to check the number plates... Looked stock, though.
Time: 09:54am
Car:Green S1
and qikstagea is thrilled to know his car is recognisable from a distance... - thats what its all about ladies and gents. poser value. oh and comfort etc.
my fiance had the car that day though... cos i have no licence atm... but yep was definitely it.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
