' date='25 May 2006, 04:20 PM' post='2201322']
wanna buy my wheels??? :)
haven't seen that pic before either. Car could be coming to sydney for Final Battle Autosalon too.
What new wheels you looking at man? That thing would be perfect with a new front bar! I 'think' I will be going in Autosalon Newcastle - havnt decided yet though
Spotted a Bayside Blue S2 just off Swan Street in Richmond last night around 11pm, Ian was that you? That's my first spot outside of Auto Salon, was pretty excited had to rub my eyes a couple of times to make sure it was really there! We were parked on the opposite side of the road, in the Commodore though... Would have been classic to have 2 Stagea's parked in the same street, need to get my alarm installed so I can remove the 5K theft excess! :)
Cheers
Luke
well if it were a s2 then unfortunately was not me...
although i have been on Swan st a couple of times this week and weekend.
OHH spotted a white S1 this morning on the way to work Corner Burwood Hwy and Springvale Rd....
though it was Alex as it was identical to his although i was wrong.... unless alex lent his car out??
Time: 09:54am
Place: Caloundra Turn Off
Direction: North on the Bruce Hwy
Car:Green S1
Identity: Qikstagea - I think.
I was heading South at the time (yellow S2) and I dont think the driver looked over. I tried to flash the lights but we had almost passed by then. What really freaked me out was that as soon as I saw the Stagea from a distance I said to the wife - there's qikstagea - didnt even have to think about it...I must be on this forum too much as I have only ever seen one picture of his car.
Spotted a Pearl White Stagea (s1) parked in Macquarie Street in Parramatta (NSW) this afternoon. I was on the way home from work, keeping my eyes open for traffic and kamakaze pedestrians, so by the time I realised what it was, it was too late for me to check the number plates... Looked stock, though.
Time: 09:54am
Car:Green S1
and qikstagea is thrilled to know his car is recognisable from a distance... - thats what its all about ladies and gents. poser value. oh and comfort etc.
my fiance had the car that day though... cos i have no licence atm... but yep was definitely it.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
