Spotted Luke today driving past me on Lathlain St in Belconnen. Also saw Marc2 out of the corner of my eye as I was driving around yesterday in Belco.
yeah i seen 1 too but it was side ways in the wet and was bouncing off the limiter looked awesome !
Geez, Marcs Stag looks great, hey.
Dont know whether it was me sideways in the wet.....but I couldn't say it wasn't me......... :rolleyes:
By the way Andrew, my heartiest congratulations to you and your partner on the arrival of your son, Rohan. He's a good looking rooster too!! Well done :blink:
Hey there, saw you too gave you the thumbs up! was on my way to Footy training. yours looked sweet sitting there in the front of the line!
Cheers, Tim
Spotted 5:15 in Melbourne, Tim (Herbietjh) on Whitehorse Rd heading to work??? i was in the silver Stagea. :yes:
spotted a white s1,nice looking car,exhaust,real low,nice in white,driving down ranford road,livingston,i was working in the new sub division there,also spotted silver s2 at corner of kenwick link and .....??? in kenwick,and a stock silver s1 with skirt kit @ a house on spring road,thornlie,few gettin round now
I saw literally 7 stageas in a park in granville today. and a 31 wagon hanger on
:) Me too!
Also saw a white s2 parked near Toongabbie (NSW) station last night with Victorian plates on it, UYV-??? I think. I left some SAU business cards on the side window, so hopefully they'll come onto the site if they're not already...
spotted: red with wheels, exhaust and low - think it was a s1 on Mt tamborine this afternoon - followed it all the way down the mountain, but it didn't wave back - may not have seen me - i was 2 cars back
:domokun: Me too!
Yeah what time was this? I was in the area then too ......didnt see the white one tho
It was around 7.30pm, Ian. It was parked near the hairdresser's and restaurant along Portico Parade, which is the stretch of road that goes along the railway line on the side with the shops and banks, etc. on it.
Next time you're in the area, give me a buzz. I'm VERY local to that.
I'm not sure I gave you my number, so I'll send it to you in a PM now.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
