Spotted RBPOWA at RE Custom's today when i was dropping off my Stag.. tuff look Stagea, R34 GTR Wheels and nice hidden cooler :P
hey cheers man .... see your sitting out the front just before .... all done ? AWD working ok? ... nice touch with the duct tape too hehe ... should hunt down the front bar that was on it before you got it ... that looked nice as man.... did they sell it to you with air mushroom on it ? ... with RWC ?
Yeah my front bar is screwed!.. they chopped the hell out of that one to make it fit over the cooler which took all the strenth out of it and stress from bumpy roads ect made it crack all the way through! :D.. I've got a new Nismo bar for it just gotta get my new cooler, get the bar sprayed and fitted.. Old bar was an ABFlug bar, contacted ABFlug in Japan and they said it would cost me nearly $2000 for the bar and freight to Aus.. Brad is still working on the AWD just hopeing its gets sorted befor i drive the car through the front window of the place i brought it from!..
Edited by SHIZNT
Yeah my front bar is screwed!.. they chopped the hell out of that one to make it fit over the cooler which took all the strenth out of it and stress from bumpy roads ect made it crack all the way through! :P.. I've got a new Nismo bar for it just gotta get my new cooler, get the bar sprayed and fitted.. Old bar was an ABFlug bar, contacted ABFlug in Japan and they said it would cost me nearly $2000 for the bar and freight to Aus.. Brad is still working on the AWD just hopeing its gets sorted befor i drive the car through the front window of the place i brought it from!..
bloody shitty car yard ... u know who it is .. we just cant slag off ... did u see my cooler ? did u look under my hood ? its a perfect fit .... justjap.com .... HPI $799
hope u got a discount on your car for such a shitty replacement bar ... should go there with the quote from ABflug and ask for a refund ... if not ... things happen :S
Yeah trust me i got a discount after i went to inspect the car after the repairs and i seen the front bar the way it was.. and after all this crap has started with the car all they can say is "Oh thats no good".. I saw your cooler its tucked away very nicely.. i thought your car was stock apart from the wheels until i had a closer look lol.. didn't get to look under the hood, i only had time to drop the car off and jump on a train back to the city for work..
oh shit no spare car ... i feel sorry for those guys who leave there gtr's there for months getting rebuilt .... no spare car .. i just work 10mins down from them so its all good .. im there a fair bit .. my mate owns the GTiR there
hey ppls i'm a stagea virgin
can you give me an idea on how much these are worth ????
11998 Stagea Rs 260 Autech Wagon, 102000kms, full GTR wagon pearl white
hi and welcome cheeky, question should be in general topics but it,s pretty easy to get an idea of prices, check normal avenues like drive.com, cars guide etc also check importers, j-spec, prestige etc, you will find 260rs prices all over the shop from as low as $25k to as high as $35k just like r34 prices 99-2000 models from $20to $30k(buy the way do you have a 260 ?)
hey leetom
dont have one yet going to look test drive tomorrow
very excited just imported and complied
On sats,I dliver furnitures,and today I delivered to a bloke in coburg,that has a white pearl 2001 stag rs !!!!!!!!!!!!!!!!!!!
very nice ride,with front mounted intercooler +etc
It has the carbon fiber gauge cluster!!! :3some: .
We talked that would be good to have a stag ride here in melb one of this dayz... :D
I was looking for some data about a turbo timer on the net and i cross my way with this ...
Take a look at this rides...
Look they are a couple of stagea's clubs in Japan(think one of them is people with dolphin bodykits...)
love the pic with the mount fuji at the back...
i got a apex-i pen style turbo timer .. has volter meter o2 sensor and a/f reading on it ... all works good easy to hide also .. car thievs look for them cause it leads back to the main ignition wire then boom car gone :D just a tip i recived of my mech !
Edited by RBPOWA
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
