no it lives outside my pants!
the trip was good! the stagea behaved itself, my boot full of shit didnt, and i almost ended up with a few tables and boxes in the back of my head when hitting the anchors a little too hard lol
and yeah the stag will be there next time! possibly this thursday if the meet is on still!
passed a White S1 with black bonnet on outside Sandown Park Train Station tonight around 6:45pm.
reaction wasnt fast enough to do anything haha, might of Been FUZZY's ex car ....
nah not my old car. Hasn't been driven since new owner was in an acco with it.
seen 2 down beachport (south east SA) a red s1 in town and a s3 between beachport and millicent. that was the last thing i was expecting to see down there. lol
i claim the red S1. good looking car there fat_stag, hope you find a rim.
rob.
Spotted a white M35 (not sure which model) heading south at Tarren Point with 3 bikes on the roof around 10am today.
Looked at the bikes first and then realized as I looked in the mirror that it was a M35.
Also spotted the dumped white S2 in .................. whilst out and about. (if you have had your car stolen this may be yours)
Cheers
Andy
Spotted a silver WC34 (didn't get a good look at front end) at the intersection of Parramatta Road and Bold Road, Granville @ around 11.30am.
Gave them a few hoots of the horn as I passed them heading towards the Motorway.
Spotted a blue/purple colour M35 turning down New Cleveland Road from Old Cleveland Road near Capalaba. Looked very nice :D
That's me - stock except for resonator in place of that dodgy exhaust box Nissan saw fit to install. What a great car the m35 is to drive, I've just bought it and its immaculate!
Congratulations mate. Looks like a very tidy car. I'll have to drive one of these some day. Everyone raves about them.
Spotted, heading west on Reid highway at Beechboro road intersection, silver (or white) RS4 at 1145 hrs yesterday. Only got side on view, I was stuck in que waiting to turn onto Reid heading east, dunno if S1 or S2.
:S thats no good, hope all is alright though
Yeah its repairable.
Shouuld see it back on the road soon hopefully ... just i think sourcing the parts could be the longest wait.
Pretty much needs a new f/bar, bonnet, reo, radiator, headlight ... thats bout it.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
