Never seen so many stages in one day!. Once again i sore someones R34 front end conversion down at southport in the marina carpark, and opposite that car park was a nice serious one. I then sore another green serious one at the lights before the southport bridge. I was in a yellow c34 ;)
spotted a white stag this arvo round 1:10pm on beecroft rd, and also a stag tonight along kissing point rd number plate "DA2126"
That second one is Alex CL11QE. It's pearl white, Drew, so maybe you saw the same car twice, I dunno...
