spotted a white S2 with front mount next to the bp in southmelbourne near crown, i dont remember too much else cause abit boozed from the races all day but im pretty sure i spoke to u and u said ur name but abit to f**ked to remember....... hope i find u hehe.. it was an RSfour, thats all i remember
that was me. I just finished work. yay I got spotted!!!
Spotted a white s2 RS-Four S at Cherrybrook outside some mega-dodgy pool shop.
Hi Alex! :banana:
LOL HAI NICK! :(
And on that note, spotted a green s1 outside my mega-dodgy pool shop, which out
of interest is technically in Castle Hill not Cherrybrook, but back to the s1, i heard
his seats got stolen out of it next weekend :)
In the last 3x days Spotted;
-Yellow S2 North bound M1 Nerang
-Yellow Stagea/R34 front Nerang Broad Beach RD, East bound
-Silver S2 Miami, GC HWY
-White M35, KFC Robina
Goldy is going off! :P
Edited by JDM_Spirit
Goldy is going off! :banana:
That may have been me :banana: from slacks creek to coolangatta in the morning, and all the way back in the arvo.... no wonder i have almost racked up 60,000k's in a year... poor stag :D
I spotted another yellow rsfour-s in nerang yesterday afternoon, with female driver. nice ride !
That may have been me :D from slacks creek to coolangatta in the morning, and all the way back in the arvo.... no wonder i have almost racked up 60,000k's in a year... poor stag :)
Thanks :) , That'll be the missus!
I thought it might have been ! looks great mate. has it got a fmic ? noticed front bar has been chopped in the centre where number plate goes but didn't get a good look.
I'm finally pretty happy with it atm! Cars straight, tuned and looks the goods!
Days front bar finally repaired and modified, number plate and verticals cut out then moulded flat + cheap mesh hiding Greddy fmic.
Next is a lick of paint for the bonnet and tailgate, then turbo and brembo's!
Anyone know where i get honeycomb mesh in similar size to S2 grill?
Spotted Andy's car in the carpark of one of the locals tonight, woulda come found ya but
the line was too massive and i was hungry!
I was quite tripped out at first as i drove in and saw a white stagea staring me in the face!
spotted a black stag coming off the m2 onto pennant hills road north bound this morning at around 1.15am.. any one on here... i was the guy in the ute with the rolled 4runner on the trailer!!
that was most definatly me! and i remember ur runner caz of the trailer on the bak... finally been spotted :( lol i was heading up to hornsby to visit mates after work haha
Edited by IL11TE
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
