lol....you spotted the M35 next you but missed the white C34 behind you Nic!
:P
So I am not the only one that thinks that a C34 can be confused for a Camry wagon!!!!
No, gents, that was an R33 four-door.
Oh, today I spotted another 2 C34's - one was a silver s1 heading along Abbott Rd onto Seven Hills Rd/Prospect Highway in Seven Hills around 4.30PM, the other was a white s2 on King Street in Newtown around 8.30PM.
u were parked near st joes school, there was nobody in it when i drove through the intersection
That was around the back of the main street?yes i was at an Easter service. sorry i missed you :thumbsup:
I keep seeing this Stagea in my garage. Six weeks now. Soon to be over. I hope.
Hope that radiator is helping that problem! :(
I am also spotting my car in my driveway everyday, slowly being put back together... :thumbsup:
Spotted a silver s1 C34 this afternoon parked in Wentworthville just off Darcy Rd at around 3PM, rego BGK-something-something-L or similar.
I noticed a rear spoiler, and I think it also had black wheels.
Spotted what I think was this same s1 tonight, this time parked on Targo Road in Toongabbie.
Haven't seen mine in over 3 weeks - hoping it will be ready today.
Spotted a white S1 (I think) 260RS on Mt Tamborine on Sunday, around lunch time: not sure if the owner is on here.
Looked for either of Hugh's while I was up there, but to no avail.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
