Is that still on?
Yeah, First time up there, I start from berowra truck stop if your in.
C34 silver, no idea about s1 or 2, about 830 Southern Cross drive heading towards the city, stuck in the ever present Sydney traffic jam :starwars:
Of course it is, mate! It's been going for close to 5 years now, and I think the only time it's really dead is if it's too close to Christmas or New Year's.
or except when I turn up! I was Berowra truck stop 2 weeks ago now, it was blowing a gail and freezing cold. Only one other person showed up! So we done a little run down to Brooklyn on the old road and then went home lol.
I just spotted a wine red M35 drive past me on Station Road, on the border of Seven Hills and Toongabbie. I don't think it was Stephen (Bis-e Bee).
You are right, it was not i! My car was at South Granville as I was at work. However if you are around Greystanes Road and the Highway around 610pm weeknights you might spot me as I cut in through Greystanes/Merrylands to get to South Granville. Far better than the pain of the M4.
Spotted a multi-coloured series 1 on Annangrove Rd yesterday morning...
that would be Mark from Hills Motorsport...he has recently seen the light and picked up a stag. hasn't got around to painting it yet :D
one day i might show up again. and this time ill drive a stagea!
I'll believe it when I see it... :D
Really? I've seen a multi-coloured one around Rouse Hill too quite a while ago, and it had "L" plates on it.
Oh, I spotted sh@un today at the SAU-NSW Texikhana, and also another silver one (s2? I can't remember - was too busy all day, my brain is tired so my memory is shot), and a white s1 260RS.
630pm Saturday night, Black M35, Funny go fast strips down the side :D Hi Jetwreck! Think the Mrs was behind the wheel, coming back from Hornsby.
lol...you mean the please don't run into me stripes....yeh had to lend it :D
yer the white s1 260 was me came out for a look, now i'm wishing i entered the big ass bitch looked like a lot of fun.. Owell there is always next time..
There certainly is a next time, and it's not too far off - keep your eyes on the NSW Events section!!!
I was entered, but as you may have noticed my car stayed in the carpark while I was stuck on BBQ duties...
Silver S2 was me, just called in for a bit to watch
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
