Do you live in the area, Skittles? I'm not far from there either.
Yeah I live down the road from the TLC :)
Where abouts are you?
Thanks for the props SKITTLES......... if it was clean, then it would have been just after I'd washed it.........damn indian minors made camp in the transformer out the front of my house & shat all over the bonnet. Not parking it there any more. :angry: Hope they dont blow it up again.
I know what you mean RE: birds.
The tways has pissed off the birds on our street because they don't have their trees for houses anymore, so they're having a territory war with the black/brown ones. We get soooo many birds shitting everywhere >< I washed my car, went inside, grabbed a drink, walked back out and my car had bird shit on it. *sigh
I drive a black R32 and silver R33.
I live just off Station Road, a bit past the bowling club. You must see StageIan's red s2 Stagea a fair bit, then.
Spotted white c34 parked on kenthurst rd near round corner yesterday afternoon
If it had black wheels that was me, had a couple of days work up in the shopping centre.
I have also been spotting a silver S1 c34 on and off at the end of my street over the last few days just off Bunnerong Rd Matraville near the BP in the east of Sydney.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
