Spotted a silver C34 S2 parked on Wentworthville Ave Pendle Hill across the road from Harper Timber @ 4.45 this arvo.
I think the dude that owns that works there (right near the smash repairer's), I've seen it parked there a few times.
spotted a red S2 C34 in the gawler woolworths/big w car park at 7:30 last night looked pretty mint gave the wave plus we both had cheesy grins on our faces...funnily enough had the same highlight out
