spotted a white s2 c34 on diagonal road about 3:45 looked clean as plates stg 034 I think :)
did wave but I was in my daily
That was me =) oh I'm sorry I didn't c u wave otherwise i would of waved even thou u werent in ur stag lol but I was a passenger in my car so I wasn't focusing on the road and thanks
Grey c34 parked on Bunnerong Rd at Daceyville just now
Going back a while but a 260RS with works gold wheels.....It was me then, thanks for the spot,
I spotted a blue C34 + exhaust + many stickers on the rear window being driven very slowly and carefully, (possibly the owners dad as he didn't even acknowledge another stag) Saturday night in the M5 east tunnel
Edited by Tyre Kicker
High 5 to the bloke in the blue M35 i saw on Pirie St today.
Made my day mate, you look like you were so excited to see another one you almost wedged your entire body out the window!
hahahaha that was me, i wasnt sure if you would see me so i got as far out as i could, plus i haven't seen any M35s for a while
Nice one.
Make sure you come to the cruise then, you'll see a couple more :P
White c34 Hume hwy liverpool This morning
i think that was my flatmate, he does the hume twice a day everyday, white S2?
i saw a white S2 on cowpasture road roughly around 830am, i was on the opposite side of the road in my white S1 [waving like a spastic :lol: ]
thought that was going to be me till you mentioned the fact that he saw you in your M35 :P I park up the top end of Pirie most days!
Saw gold ARX on Whitehorse road Box Hill about 3:15pm today being driven by what appeared to be a 'very' elderly gentleman . Pulled up next to me - didn't even move his head when i was trying to give him the thumbs up.
Car was stock as a rock .....must admit at first glance i did think it was a Volvo :domokun: but i think that was because i first saw the Senior citizen driving it.
No offence intended, but doubt he would be on SAU (he was definitely around 70) - if you are - great!!!! If you're not - i hope you enjoy the boost!!! :yes:
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
