I saw your car parked on St George's Pde one day last week. Great looking kit on it.
Woah Tripout...
You would have seen My white R34 parked there, It seems like we have our little JDM meets in St Georges pde!
How good is the little matt black ke70 with the HAIdmst sticker!
100% Home job lol.
Vic: spotted a silver r x M35 gold 19"s on the m1 first at high st rd overpass... Stalked you still you turned off at Blackburn at about 5:45 nice Pm ride. Heard your turbo whine, stock other than rims yeah?
Edited by TWOAR81
caught up with Craig on the SAU cruise on sunday was nice to finally meet you seeing as you only live 5mins away LOL.
but spotted a silver M35 drive past the meet up outside bunnings in Kirrawee but he never stopped or came along............... could've been Rudi??? or a similar looking one
maroon c34 in north sydney parked across from a pub, see him a few times, only got a quick look at the plates but the rough combination of letters and numbers spelt ST49EA or something similar.. honked as i went by but it was dark :)
Seems to be a lot of stags in north Sydney lately - is it the hamish pub?
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
