on Cowarra st taren point i saw a Silver PNM35 at a fiberglass place and then while i was watching it a White C34 drove past then of course there was my Black m35, i personally have never seen more stags in one place at one time.
You should cruise down to stagea hks Nismo fully sic bro garage sometime! ;p
Spotted a Black Series 2 on Main South road, just near Flinders UNI in Adelaide at about 1:20PM today.
Also spotted a White Series 2 on Flagstaff road at about 3am on Saturday morning. Turned off before I caught up.
Very nice s2, blue, pulling on to hawker street this morning. I was in my pulsar so didn't wave today. Seen you around a few times.i live over the road with a white s2, in the shed at the moment few little things to do.
Spotted a Silver C34 pulling away from a park in Emu Plains when I was pulling up.
My young bloke saw a tractor in the park; so that's where we were going (with a minor detour to the Nissan dealer first).
spotted a S1 260RS on Victoria rd this morning. followed it all the way to harris st where I overtook in traffic. looks good in the grey!
If it was Lowered on bronze works wheels then it was me, thanks for the spot.......looks the best in grey ;)
I'm guessing you were in a skoda and not a stag anymore, would have noticed if a stagea over took me.
Spotted a silver 350RX at the Sydney Datsun Show today @ Prospect Hotel. It was parked around the back as if it was being hidden away... :(
277197_10151158013215369_1923639940_o by GoldZilla, on Flickr
Spotted a White C34 turning onto Grose Vale Rd in North Richmond this arvo.
Was in the far left lane on my Black Gixxer 1000, and didn't notice until you'd pulled away.
Plates look good, pretty nice exhaust note too. ;)
yup sounds like it was you! you work around the city? I turned off harris st as I passed you. yeah was in a dark grey Octavia.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
