saw RBPOWA (SP) on glynburn road.
That would be me. I take it u were in the s2 rs?
Also spotted a s2 bayside blue at the bp on lower north east rd as I pulled in to get fuel u were leaving
white C34 with gold/bronze rims weaving in and out of traffic, from the M4 all the way up to ryde this afternoon. in my black 34, no love shown =(
:action-smiley-069: hi Chris, sorry too busy hooning to wave :) Nice 34 BTW
Spotted a Black S2 Stagea a few times now around Burwood East over last 2-3months on Highbury Rd and Blackburn Rd
Same with a White S2, also keep seeing a White M35 in same area. Sometimes up on Springvale Rd.
Exchanged headlights, waves, toot the horn a few times.
Yellow S2 Stagea with R34 kit also in same area also.
Got a thumbs up and a wave from the bloke with the other silver m35 down the end of Targo Rd on the weekend.
Dave, it wasn't you I saw the other night on Gilba Road (crossing Targo) and then again about 20mins later in Toongabbie near the servo on Cornelia?
Hey mate, yeh I saw your post, and the times were near when I was getting around those areas, but I turn left from Targo onto Gilba, and you mentioned Junia and Cornelia? I was parked in the servo on Cornelia that's opposite toongabbie shops, I just re-read your post I thought u said Lucretia and Cornelia, not Junia, but yeh for sure that would have been me then :)
Edited by DaveM35
That was me in the Black C34.....probably wont be seeing you on Highbury Rd anymore as Im not working at the same place anymore so taking a different route to work now :P
Spotted a white M35, looked like aero kit on King Georges Rd at 11am right near AutoStyle, was dumped on black rims with copper brembos, really nice looking ride.
Then around 1:30 saw a yellow c34 on Sunnyholt rd Blacktown, near Vardys Rd.
Saw a black M35, most likely an AXIS, on the M2 Motorway heading south-west between the Pennant Hills Road and Windsor Road exits, roughly 5.45pm last night. I was heading in the other direction and about to get off the M2 at Pennant Hills Road.
