Silver ARX across from the beach at Lennox. Was Leigh up from Port Macquarie. Drove great for full exhaust & fmic. I strongly suspect a hi-flow of similar spec to Dale's was installed previously.
Spotted a gold arc with black rims on Elizabeth st in Waterloo yesterday afternoon.
That was probably me. I'm working around there atm. What were you driving? That was the first time i have been spotted.
Ever since i bought my m35 last Christmas , I have not seen any stags on the road yet
Kinda feels lonely :(
Is there any around Livo area or Burwood area where i work ?
Im in a Gold ARX
Edited by FrancoLam
Im in a Gold ARX
I'm in concord and also in a gold AR-X. Where do you work?
