What's this??
Another canary stag in Adelaide! Is the owner on here? I want to find out what exhaust you fitted haha
Wow, lowering and the larger set of GTR wheels actually makes the car look physically smaller in that photo!
Spotted two silver m35s on Sat, one with what looked like a freeway dolphin kit at Holmsglen tafe VIC about 9:30am and the other traveling in the opposite direction to me on High St about 6:00pm I gave the driver a thumbs up and got one back!
What's this??
That's Mike (i reckon thats his name) he walks his dog there nearly every day.
What's this??
If its who I think It Is he goes to the dog park you're parked at with his German shepherd x akita. It used to be my stag, his yellow one and another yellow one parked there every night haha
living in north lakes, went out to mount nebo for a day trip... only bought the car on friday!
love it in the sticks though.. wish i could afford a house out there :(
where were you heading?
HAHA! the avatar is meant to headbang..
I'm house sitting my oldies at Clear Mountain while they're caravanning around. I was heading out to grab some beers for band practice - good thing about a house in the sticks, no noise restrictions!! Pity there were cars in front of you, that's a lovely straight for some punchin'...
Yeah, babies NEVER head bang when you want them too!! HA HA!!
is a good straight, but my luck, every time i drive through there, someone always ends up in front of me :whistling: dont know how that keeps happening :P
gotta love not having noise restriction problems, enjoy it while you can!
oh to be able to watch movies and enjoy the surround sound!
would be good to be able to drive around and enjoy the scenery!
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
