Spotted a silver s1 on Northern express way around 4.30 last night going through the a 25 construction zone without any work going on. Car was looking good I boosted as u pulled out and thought it was a highway cop for a while waiting to pounce
White C34 RS4S Dayz on Greensborough Bypass up and through the Civic Drive roundabout. Eventually turned right off Diamond Creek Rd down Aqueduct Rd towards St Helena.
I was on the matte black CBR1000 and gave you the thumbs up.
*Sunday arvo/evening saw a white S2 C34 on Douglas Rd, Blacktown was with a light blue BA Falcon.
*Tuesday spotted a burgundy M35 dropped on its arse at Hawkesbury UNI.
* Wednesday arvo 2:30ish spotted a silver Axis on George St, South Windsor.
Got distracted while half asleep this morning admiring a silver c34s2 on goodwood rd this morning and totally blazed a speeding camera.. cheers for the warning btw it just didnt register due to the aforementioned half asleep mode.. *facepalm*.. second one in 2 months after nothing in the last 6 years.. Nice ride you have
Edited by staglover
What are the chances of two Lightning Yellow C34 S2 RS FOUR S's cresting the top of a sharp steep hill from opposite directions?
Well it happened this morning...WOOHOO!!!!!
Spotted a lightning yellow S2 C34 this morning on Gilbert Rd, Castle Hill this morning at 9:20 this morning. Flashes & waves all round!!!
Kellyville Ridge was me.
I don't think the other one I saw yesterday is on here.
Your car sure stands out. I also saw a red c34 pulling out of kellyville ridge a the ettamogah on Friday around lunch time
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
