http://www.skylinesaustralia.com/forums/sh...ead.php?t=53548
for those that don't venture outside the protective sphere that is the victoria section :P
and for those that can't be bothered clicking, just trying to get the measurement of the R34 GTR rear spoiler. From the base to the top of the support, so not the actual wing bit, just the height of the struts/support/pillary type things. I've found a copy wing but looks too tall, measurement, bout 22.75cm's.
cheers.
https://www.sau.com.au/forums/topic/53565-r34-gtr-owners-help-required/
PHATT!!!!!!!!!!!!!!!! maybe, i'll find the pic of the one i'm looking at...
As far as i know, Racepace is like the opposite side of Melbourne to me? Am i wrong? And my pulsar didn't like going 100 last time i took her on the west gate, something started rattling at 90 :D
Troy, you out there mate? wanna get a ruler to that rear spoiler of yours?? :(
again, that black R34 is phat!!!!!!!!!! :P
Who around here owns an R34 GTR?   :confused:
i dunno? :confused: altho i heard some tool drives this Blue R34 GTR, but he doesn't know how to drive and keeps screwing his gearbox. More dollars than cents if you ask me :P
i don't think the rims on the black GTR are BBS, definitely not LM's as there are no visible studs. The spoke pattern is very similar, and lots of companies do the same pattern, but i have seen those rims somewhere before cos i rember the dish to them. I reckon they look really good on a black car (dark rims).
thanks for that Sai! :D
Looks like Shin switched from those dark rims to the TE-37's. You don't happen to know what the original rims on the car were do ya Sai?? the one from this thread...
http://www.gtr.co.uk/forum/upload/showthre...&highlight=shin
http://www.bbsdirect.co.uk/
I believe they're the BBS RC - a lot of wheels from BBS look like the LM so everyone just says they're LMs.
here also
http://www.gtr.co.uk/forum/upload/showthre...8&highlight=BBS
Dont JMS and UAS have R34 GTR copies?? the proper sized ones?
yeah, but carmate only wants $360. I could prob get a genuine one from Yahoo for that price. Not going to spend close to $700 for a copy wing. Maybe i could chop up wth the carmate one?? :confused:
Sai, they're definitely close but quite the same. The ones on Shin's car and this car...
have a little dish to them. The spoke don't sit right on the edge like the BBS ones. It's a popular spoke design, hard to find the right company :D
thanks guys.
Oh and ni i think JMS said their mould corroded for their rear wing, they only wanted lke $400. I think the UAS one is a rip for being it's a replica.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
