i use redline mt 90 gear oil.... no smell and works very well......
could be clutch smell as above post...
could be the rubber boot around the gear shift split.. this will weap oil onto the top of the gearbox and smell a bit..
hope this helps...
jezzerrr, had the same problem with my 33 GTR when I first bought it. I would smell gearbox oil fumes whilst driving. The problem was a split in the small seal below my gear stick, that was allowing fumes to leak into the cabin. I got a mechanic to change it - part was 25 bucks (From nissan) and labour was 50. They accessed the seal by removing the gear stick boot. Apparently there are two seals, a larger one and a smaller one. The smaller one was split.
Hope this helps.
Hope this helps.
Omg... you spent $50 just to get someone to change a rubber boot?
Dude, next time just pull it apart yourself. 4 screws under the vinyl selector cover removes the big boot, then the one that is nomally cracked is the smaller one which just slides onto the gearbox.
took me 3-4 mins max.
:bananaman
You used automatic transmission fluid in a manual box? Is atf not too thick?
The ATF is used in the Transfer case on the GTR box (at the rear of the box) The gearstick enters this part of the box, and it is quite smelly if there is a leak.
The front of the box is for the gears, and will use a manual gear oil (redline is good)
If you filled them around the wrong way, or used one oil for the whole box.. it would need to be flushed.
And $50 to replace the inner boot.. bit steep.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
