  • Replies 46
I'm going through imports101 actually. So they basically do a to ur door service. Organise everything and other than pay them money (the hardest part!) you don't HAVE to do anything. I'm getting Danny to give me run downs on everything that is getting down, how they go about it, who they go through, etc etc so next time (cmon, you all know there'll be one :P) I can do it myself, or at least the majority anyway).
So I guess my answer is I'll tell you how I (they) went about it when its done :D
Boostworx is also good.
Shaun tunes the better known hipo street Skylines getting around Adelaide.
Not to mention he's pulled ~280rwkw out of a stock RB25DET & an internal gate turbo, it appears to be holding together perfectly fine.
What better known Skylines has Shaun tuned?
I'd recommend Mark Tilbrook from personal experience.
he tuned one of our member "whatisname"'s car, which has 299.1rwkw? :)
i go to boostworx as well, it's good to go to a workshop that the owner has loads of exp. and he is the only one do all the job.
Looks like Mark Tilbrook uses Tim Possingham to tune these days.
Tim is a good tuner. He tunes safe.
If Tim is tuning the car I don't have an issue. If its some other hack then I wouldn't get my car tuned at Tilbrooks.
Back to boostworx.
Freebaggin (~280kw on stock motor) & whatsisname 299.1rwkw.
Darrens R32 RB30DET (that will be making upwards of 350rwkw soon) and my RB30DET (~300rwkw) will also be tuned there once it is run in.
It really depends where you live..
Down southish - Boostworx.
Up North - Tilbrooks (Providing its Tim that does the tune)
Always a topic that generates much debate (mostly heated!)
I know both Tim (Tilbrooks main tuner) and Shaun (Boost worX) personally. Both are excellent blokes and both have a wealth of performance tuning knowledge. I would recommend either of them for tuning work.
For all round tuning 'and' performance work I would recommend Shaun without hesitation. I have been taking my car to Boost worX for some time now. Before that I used RPM (once owned by Tim and later managed by Shaun!). As I know Shaun reasonably well he always looks after me. I have never used Tilbrook Auto and Dyno but I do know and have chatted to Mark on many occasions. He is a decent bloke.
i kno tilbrooks has experience with skylines. he dyno'd my mates et and got 100fwkw outta it runnin on 15psi. but he had a fairl bad fuel dump. tilbrooks was recommended to my mate by the mechanic at jap-tech
RPM are under new management.
I don't think they are dodgy.
I used to take my car there when Tim owned it a couple of years ago.
Since then up until this RB30DET I haven't really done any mods (Rb30det's are damn expensive) :/
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
