105 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 63
are you doubting the fact he'll be buying cars like the ones mentioned??????????
i think a signifcantly worked 33 GTR and E class 55 AMG should dispel that myth...
but i can't say i know what the flaming was about?
classic... must be fans of mine.. people actually go out of there way to search up my post history, Daniel, it's all because I disputed a forums members dyno figures, for a stock gtr making 410kw at the rears... only in WA ofcourse.
gatty, dragqueen, pnblight.. etc thanks for the warm interest... but don't worry, I'll soldier on, and I'll be ok! again thanks for the interest.
look mate if your going to slander someone at least get your shit straight
it was not 410kw or did you finish school
529hp =396kw
and it is not stock
it has upgraded turbos ,cam ,management injector ,afms etc etc
and the reason i'm posting know in and old thread is you use my name directly some i feel i got the right to defend myself you ....ing half ..t :kick:
why the hell would you want a nur
fork out the extra 100k and call powerplay and get yourself 1 of 20 nizmo z tunes
mmmmmmm
WTF! 100K.. Well I just tried calling powerplay, and just got an answering machine, I left a message to some girl called joanne?, and called the mobile aswell, and left a message there also. If what youre saying is true, then I'll do it the deal now. But if I recall, funkymonkey saying they are no able to be complied into australia?
fatz, :slap: I just a call back from them, 100K... you kidding. it's 330K landed & complied
the process is they first import an stock standard R34 which has been hand picked by nismo, the is complied in AU, then sent back to NISMO for the Ztune mods... it returns to AU as a Ztune...
loophole? probably... but for 330K? they better be stamping the name "Carroll Shelby" somewhere.
but it's a not to be repeated price!!!! :P can't imagine these cars will depreciate?
damn... A Nismo Z Tune.... that would be crazy. Can't u just get these anyway? But if you did the process mentioned... buy a normal R34 GTR, compile and then get sent to Nismo for some Z-Tune-ness, technically it wouldn't be one of the 20 tho would it????
Couldn't you buy Z Tunes anyway? Not this limited run, just normally? Maybe find yourself a 2002 Z Tune??
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
