  • Replies 68
um... what's so spectacular about that? any kid from thomastown can drive like that... and in fact they do lol.
But congrats on further destroying your car before selling it, and then posting about it on an open forum.
yeah im sure thats much worse than whats been done to it in japan and u would have to be a moron to not know its been driven much harder than that in japan.
gees ur a spastic :D
