Well... it was pretty much as i suspected.
Found out the radiator is a larger aftermarket unit...
ECU is a standard R33 GTR ECU...
Sam took me for a drive (Dr_Drift) in it... well... now i know what it can do in the right hands hahaha when we got back i was a little shakey and in need of some new underpants but soon got over it :(
We finally got to put it on the Dyno and had a couple of runs... second one blowing a nice little flame but was restricted by the mixture reader in the exhaust pipe... so... we took it out ;)
and this happened :)
http://www.skylinesaustralia.com/photopost.../414flameon.wmv - right click save as ;) its not the greatest quality but i cant actually get the video off the camera and on to the HDD so it will have to do.
Now down to the numbers :(
The car made 207rwkw on 9PSI :)
472nm torque.
Not bad figures for a stock GTR engine.... in a 1350kg cefiro ;)
https://www.sau.com.au/forums/topic/54326-cef-zla-was-dynoed-today/
lmao guys seriously i bloody would if i could :P
taking it to calder park this friday to see what it can do down the strip just to make it even harder for me to let it go lol :D
but nah... it has to go.
dunno if u can read it all but its the first pic in my gallery :P
Do you know what kind of air/fuel ratio you were getting before you took the meter out of the exhaust? Or wouldn't it be accurate if it was restricting the exhaust?
BTW - do you only have a 2.5" exhaust or is the dyno sheet wrong?
:jump: :D
i dont know if i can get there on friday now... i cannot borrow any of the cars with tow bars cause theyre going away for the long weekend down to a friends holiday house in sorento and taking the boat... plus i dont think i can get the car trailor from a friend.
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
