You are so evil  :chairshot  :cheers:
:jk: i reckon with all that power and talk you would have to get use to it and im sure your not going to crash...............i thought cassi was the veil one
anyway i really need some sleep, nice to meet you allas this is the first time i have posted exept for the for sale items, its been fun, keep those posts going, the crown is ours:smile:
yeah Cassi is the most evil person i know (she scares me :cheers: lol) Yeha ive already been driving it for a year so i got the hang of it now.
Mad lahdaz man :cheers:
Lets us know when ur in town :)
Whats changed?
I need to pay rego soon :cheers:
There goes $670...wasted
Am not really sure wats changed. Ill check it out when it comes out.
Damn you guyz pay like $100 more for rego than down here.
Langwarren, i think that's the spelling...it's been too long...
All my family is there. Grandma in Chelsea, Grandad in Dandenong, and other people other places i forget.
I haven't been to the ol' Victoria in like 6 years.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
