My newest battlescar on the ute haha
First scar was the rust and axe/tree limb damage (when we were fixing the clutch we through it would be fun to take an axe to it, it was indeed fun) then 2 mates of mine thought it would be even better to try body denting it, they used a tree branch 3m up to jump. That was funny to watch, not to experience.
Next was back before it had started raining and the paddocks were completly dry so sliding around would make massive clouds of dust that looked like crazy tornadoes, anyway i continued sliding after going a bit crazy and could not see more than 2m in front, unexpectedly I ran into a tree stump. Took out the front bar, light, bonnet latch and radiator but luckily we had an old fairlane lying around so was just a matter of swapping parts over :thumbsup:
And the newest one is the windscreen, the car wouldn't start a few days ago and was stuck in a ditch, so i was trying to dig it out in the rain, after a few minutes i cracked a shit and smashed the windscreen in with the shovel and here it is today:
nice and slippery :spank:
Love this car, it just never dies.
Edited by Baconer
Haha yea its very refreshing except when it rains and im blinded. Probably better cooling with the radiator aswell. Took the exhaust off aswell, hard to hear after a couple mins of driving it :)
Used to have a problem with the car over heating (was a hole in the radiator) so I took the thermostat or whatever it is called (spring thing that is between radiator hose and engine block) so once the car is going it can rev continuously hard pretty much until i run out of petrol.
Good fun, built a track aswell which is great when dry but in the wet you just understeer on most of the corners which is pretty scary considering the track is marked by solid gum trees.
So she got her little beast out on the track... i want photo's of the day also any times :) pm if you don't want them up here :rolleyes:
hahaa that looks like awesome fun :D
on a different note, me and Cassi went to wakefield on sunday... we decided we wanna hire the track and have our own track day :D so no one watches us lol
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
