That's how I role ! The guy knew he was buying a lemon haha Hopefully Rosie and Helga meet at the lights and strut their business around ;)
Rosie??? Hahahaha...
It will be good when you get it on the Road... Then Black Betty can smash Rosie off the lights and you'll owe me 2 cars. :D
I only race for pink slips ! and in my defence I didn't know you were going to take off so hard. You wait Rob ! Everyone knows Red goes faster ;)
If it wasn't for the fact I just sold "the bitch" I would take you all on and have a skyline sale out the front of my house.
Pffft... Usain Bolt aint Red Buddy.
  • Like 1
My Son is Fourteen... <<---seperate incidents-->> I lost my Virgin at ...teen.
I will be 38 this year. :(
I asked one of the guys at work if his Mum's name was Melanie... When he replied No, I was like Thank f**k for that !!! :D
