Blame the bogans who drink and drive and then die in ditches on their P's.
That's just the thing - if shit like that is the "reason" behind the rules, then it's clear that logic is definitely not a word in the vocabulary of the clowns that come up with them hahaha
The turbo laws are so dumb. can't have a 160KW S15 but you can drive an N/A 200kw xr6? There is no logical reason as to why they actually implement the laws. Idiots will be idiots it doesn't matter what car they drive.
Active bunch of banana's
Oi Rosie34 (previously known as Helga33) - is that water or fading on the top of the red 34 ??
Oh and Troy boy. Thought I spotted your Caddie Shack on the way home but it was a florist :P
Edited by Sinista32
It's water on top - phew !
Who did you use in Vic to give you a written report on Rosie - can you PM me the details and cost plse ?
Did they do a wet/dry and leakdown test or do you think they would if asked ?
Edited by Sinista32
Ready to detail !!
Sent you a PM.
Edited by HelgaR33
