For real? Wow.. that does seem a bit of a rip. How big is the screen at Limelight though? This is the Extreme Screen (which I think have stated like 100x now haha sorry) but paying $12 more for a screen doesn't seem right.
Oh well, Belco Hoyts is just down the road so I'll pay my $21 :(
$21? What are you? A Uni Student, Princess? :P
$21 is nothing, it's also on the Extreme Screen so I'm assuming pricess a bit higher for a bigger screen.
$21 is a f**king joke on principal alone. That's actually MORE than it used to be. Logic says reduce pricing when there are so many people who're sick of paying so much for a movie when they could either go to Limelight and pay <$10 or just pirate it.
$21 is f**k all money, particularly for me. But I'm not paying $21 for a movie, ESPECIALLY the 6th (or is it technically 7th? I don't know) instalment in a series.
Fair enough - I don't mind paying the money :D Where the joke is in the "Candy Bar" $15 for like a Medium Popcorn and Coke? That's the joke.
we should Dendy Premium on Sunday for $38 bucks you tight arses......
Ps. Is there movie quality out there yet ?
I'd actually rather do this, though I wouldn't take advantage of it since I don't drink :(
And nah I wouldn't think there'd be any torrents worth downloading just yet, unless someone leaked the critic review copy hahaha
Any idea when it will show at the Drive-In ?
Haha this made me smile. Everyone rocking up in their Skylines to see it at the Drive-In. Good idea imo.
Also Dendy Prem is a sweet idea - I saw Iron Man 3 in Prem and it was worth it purely for the seats and lack of people being tards during the movie.
I think I'll just piratebay it lol
Excuse me sir, but that is illegal and I will be phoning the FBI and sending them your way. You sir, are destroying the movie market. You should be personally blamed for these actions and all sanctions applied to the fullest.
Thank you and have a nice day.
How about you EADC!
No more dive in.
DIY drive in: Paddock or carpark, screen(side of a building or something),projector,generator, and some wires for sound n stuff.
Wheres a carpark next to a big unlit white wall? One thats empty at night.
