Well a big turnout for the Rana's. Counted about 10-12. They were all looking really good.
A few SLR's and a beast of a Yellow one.
Doc had his mint Midnight Purple R33 GTR and there was a nice green 33 there also. A few other JDM's as well.
Steak sammiches, Sausage sizzle and cold drinks.
Well worth a looksee :w00t:
Threw together a quick video of my WTAC experience with the Division One crew http://vimeo.com/109394082
I spent 20 years working in media, predominantly TV .... so I can say with some authority .. 'not a bad little edit'. Nice vid mate.
I made a video yesterday as well. Could you review my video of my gaming eliteness? BHAHAHA
