They're very reliable, have really good handling, lookg good.
They're not very powerful however. Maybe a bit faster than the new celicas.
I'm pretty sure its faster (def. better looking) than a prelude.
Its fast enough, it still goes well.
It should put all those cars u mentioned under.
From memory I think the non-turbos were around 140-144kW.....can't remember. Im sure u'll be able to find the exact figures somewhere on this forum.
welcome to the forum, if you have used search button then you've already got most of answers.
ok R33 GTS come
R33 GTS
  • with RB20DE 2.0 litre non turbo ->DOnt get this too heavy and not enough power
R33 GTS25 ->140kw at the engine not the wheels.:P
  • with RB25DE 2.5 Litre Non-turbo -> majority of R33 NA
some will have HICCAS (four wheel steering)
some will have ABS some dont
some will have Roof windows
if you are damm lucky you will get all
R33 GTS-4 Series one or Two
  • with RB25DE with ATTESSA (Four Wheel Drive) not 4WD, only engange when computer detects rear wheels loss power -Great in wet :rofl: I had one of these
  • They are rare I've drove Series Two - they are pretty good with minor mod. (pod, ECU, EXHAUST....etc..etc)
ALL SKYLINES ARE POWER Everything, so they are Great value for money, Hardly ever breaks down (exapt damm thieves). they are top car, bang for buck:thumbsup:
As far as insurance goes IN Western Australia, there is not much difference, they are both categories as IMPORT and NO ONE will touch it. :)
if you have only money for car and dont want to spend too much money on the car then save up more and buy Turbo skyline
I hope this give you some idea.
cheers
Joe
ok R33 GTS come
R33 GTS
R33 GTS25 ->140kw at the engine not the wheels.:)
Actually GTS is RB20E - 100kw of pure SOHC power, agree with Joe, don't go there if you don't have to. GTS25's post '96 have 147kw at the engine.
Keep in mind the R33 is relatively heavy and a GTS25 is similar/slightly higher in power to the cars you've listed. But the engines have totally different characters, not much happening down low and in the mid range on the VTEC Honda's, whereas the RB NA engine is all about the mid range.....
Also the Skyline is RWD (or AWD for the GTS4), so they don't understeer round corners like the FWD Hondas etc do.
They are stupidly reliable, keep in mind it is fundamentally the same engine as the GTR has, and those can run 500hp all year and not break!
Test drive them all and see which you prefer....
hay man i own an non turbo r33 its great with the power on my p's dont have many hassels at all witht he cops and if i do i just show them its a non turbo and they are cool and for insuracne its hell of a lot cheaper then a turbo i know i just got my turbo and there are huge money jump any way if you are looking for a non turbo i have one for sale so if you want details pm me and i send some photos also i live in melbourne so yeah if you wana talk non turbos im happy to help
hey, do u have msn? i wanna talk skylines with u :P
oh and full comp. Insurance means $$$$$. Just cars quoted me $3500 full comp. But i took the 3rd party Fire and theft. $750. But they'll only refund you 5000 with 800 excess. So if someone steals it, you only get $4200 back. and if you smash something with your car they'll pay out up to $50mil (this means don't go crashing into a ferrario show room with a porsche showroom next door!)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
