and rick... i reckon it is a top idea to stay on street tyres....
the street machines white 32 is faster on streets than on slicks due to the fact that with slicks there is NO wheelspin in a 4WD and the motor bogs badly! with street tyres and Altessa there is a nice balance between slip and grip and they go HARD on street tyres.... although a big Exhaust system on that monsta would be a help..... and a HKS 30/37 Kit...... and a Trust Fuel rail....... and Microtech computer..... wait where were we..... yes stay with the street tyres... you'll be quicker and save yourself $$$ when you break stuff....
however 2WD is a different kettle of fish.....
the day that Squizz gets slicks (and a piston.... he he) is the day he runs 11's cause the morose slide states that it is and therefore it will....
and matt if you can go fast as a GTR on street tyres in a VL on STREET TYRES.... i'll give you the silvia to drive cause you must be a gun driver.... all fast 2WD cars run slicks... and that's not cause they are gay... it is cause they want to go fast.... I wish I had enough horsepower to require slicks...
so who is going to the next Day night major anyway....
it looks like it should be a top field with all the brissy guys coming up....
  • Replies 53
I'll probably come to be embarrased by some real gtr's but I was hoping to get more boost and dump pipes and cat removal by then but now some scumbag keyed the gtr while I was at the movies and of course i parked where the camera can't see, I thought they had more than one.
  • 3 years later...
  • 5 years later...
  • 4 weeks later...
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
