Hey y'all
bought myself a BATMBL 3" front/dump pipe and 3" Hi-flow CAT, so now i need a 3" CATBACK exhaust to complete the system :)
Looking at Apexi N1 or Blitz Nur spec exhausts, but can find f*ck all pictures of them on cars, not catalogue type pics. I searched all 20 pages of "apexi" thread titles, and "blitz" thread titles, and found NO pics of either exhausts on a car.
Prefer pics of these exhausts on a R34 but i guess any car/skyline really.
The other thing, does it really matter what 3" catback i get? It's basically a hollow piece of steel? Or is that simplifying things too much?
These 2 seem to sit nice and parallel to the ground and don't stick out from the rear bar (i don't want all that funky angled shit). If anyone else knows other types of exhausts that are similar shapes, i'm all ears.
cheers,
daniel.
Apexi N1 is an angled exhaust (hence the N1 designation).
I recently invested in a Trust Power Extreme II. It is also N1 style but i have found it grows on you, plus in reality the angled ones do flow better because there is not a big 90 degree bend just before the muffler.
I bought it at Advan performance in NSW who are actually a great bunch of guys and stuck the exhaust on while I waited for only $35. Even though it's a direct bolt on - the effort saved by using their hoist to undo the carbon fibre under tray and shit is totally worth $35.
Anyway these guys import trust gear into Australia and would ship it interstate - they always have Trust exhausts in stock too.
Another reason they are angled - a lowered car will scrape the muffler of a straight-out tipped exhaust because the 'departure angle' is too shallow...
If you angle them up they give better ground clearance and the tip is less likely to be destroyed :rofl:
thanks for the pics everyone, and yeah, Chris and especially CNBLOW, pics would be awesome!!
I know it would be better to have a straight as pipe possible, but i figure i won't really be able to tell a difference, so i want to go with something that i like the look of (not what the Japanese are doing :rofl: )
Blitz: it's not exactly straight, but i like the look of your exhaust. Do you mind if i ask how much?
Sewid: i ain't joining no dark side if it means i'm going to be unhappy with the way something looks on my car :rofl: You got any pics or urs?
cheers guys
cheers guys
I just went downstairs to take some pics.
Check them out:
http://www.sewid.org/mycar/BNR34/ExhaustMisc/
AHAHAHHAHAHAHAHAAHAHHA @ the ruler pic! ;)
A little too much parallax error there for me to tell, but it certainly ain't 22.75cm's is it! more like 12'ish
Car looks phat sewid. Does ur exhaust trumpet out a bit??
Hey Brendan, do you have any pics mate??
cheers
haha yeah it's hard to use a ruler to take a good measuremeant of that while taking a photo. But i'd say 12 - 14cm high.
I don't exactly know what you mean but the exhaust doesn't stick out far at all. It ends almost exactly where the stock exhaust ended. Also it's not very loud at idle but when you hit 4 or 5 grand it starts to really growl so its excellent for putting around town and not getting noticed by cops.
sorry, wasn't very clear. I mean the tip bit, trumpet out, as in, diameter gets wider just for the tip bit? Probably just the angle it was taken on.
Is it much different to an Apexi N1 shape?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
