calvintys Posted November 9, 2004 Share Posted November 9, 2004 Wheel spacers and high speed driving is bad idea.GTR rims should be around +25 offset then you would need spacers to make the rims fit properly I will NEVER EVER use spacers on a performance car.... it is just too risky for anything to happen. Link to comment https://www.sau.com.au/forums/topic/55144-which-tyres-to-buy/page/2/#findComment-1082125 Share on other sites More sharing options...
performance-wise Posted November 9, 2004 Share Posted November 9, 2004 Im running falkens on mine, Are these any good?? Link to comment https://www.sau.com.au/forums/topic/55144-which-tyres-to-buy/page/2/#findComment-1082151 Share on other sites More sharing options...
paulr33 Posted November 9, 2004 Share Posted November 9, 2004 mm i woudlnt be a fan of second hand tyres i recently got dunlop direzza's 255s on the rear, about $400 each fitted friggin awesome tyres, very nice, comparable to pzero 255s which i had previously Link to comment https://www.sau.com.au/forums/topic/55144-which-tyres-to-buy/page/2/#findComment-1082187 Share on other sites More sharing options...
R31Nismoid Posted November 9, 2004 Share Posted November 9, 2004 you buy second hand tyres cheap for one reason... once they have been fried, they loose thier traction. thats why they are cheap, as they are not performing like a new tyre would. I've just put sumitomo all round on my car $300 each, on 18's They are very grippy, had em for 1,000km's so far and wet/dry they aint too bad considering they are on my car and its RWD Oh, and i wont fry these tyres, did that with other tyres i've had and they are never the same (hence cheap 2nd) Link to comment https://www.sau.com.au/forums/topic/55144-which-tyres-to-buy/page/2/#findComment-1082343 Share on other sites More sharing options...
Jimbo2000 Posted November 10, 2004 Share Posted November 10, 2004 jimbo: 180 each for 265/35/18? Negative my mistake :Oops: he must have edited in the size after my post Link to comment https://www.sau.com.au/forums/topic/55144-which-tyres-to-buy/page/2/#findComment-1082647 Share on other sites More sharing options...
beefy Posted November 10, 2004 Author Share Posted November 10, 2004 Well guys TruTrack in North Melbourne did confirm that the rear tyres are rooted and need to be changed straight away. So now I have decided to go all new tyres ... 265 X 18 X 35 Hankooks K104's all round .. will be picking up the car in a few hours so I'll let you know what I think. TruTrack also balanced the car and I swear it is steering real sweet!! Spacers, yah I know not the best but I have got fond of my Rims and dont want to spend $4k on some new ones. Plus the spacers are the type that bolt on to the car (dunno if that makes a difference) Link to comment https://www.sau.com.au/forums/topic/55144-which-tyres-to-buy/page/2/#findComment-1082693 Share on other sites More sharing options...
INASNT Posted November 10, 2004 Share Posted November 10, 2004 I have 235 40 front and 265 35 rear K104 also, and they are a preety decent tyre for the prize. Link to comment https://www.sau.com.au/forums/topic/55144-which-tyres-to-buy/page/2/#findComment-1082923 Share on other sites More sharing options...
ferni Posted November 10, 2004 Share Posted November 10, 2004 Let us know what you think of the hankooks beefy - i've got them on my car and find them pretty good for the road... what tyre did you have on before? are the 2nd hand tyre joint giving you your money back for the 2nd hand ones? what was actualy wrong with them? as for spacers i've heard different reports from different people... i don't see the problem with them, can anyone give a proven reason that spacers are bad for performance vehicles? they may add a little extra load on the hubs, but so would putting wheels with more offset on? I don't have spacers, but i wouldn't mind getting some to get my 34GTR rims to fill the guards a bit better when i have some spare cash Link to comment https://www.sau.com.au/forums/topic/55144-which-tyres-to-buy/page/2/#findComment-1082928 Share on other sites More sharing options...
Bass Junky Posted November 10, 2004 Share Posted November 10, 2004 Isn't the load meant to go on the middle of the buh, not the bolts? if the spacer is big enough, wouldn't it mean the load is going straight through the bolts? Link to comment https://www.sau.com.au/forums/topic/55144-which-tyres-to-buy/page/2/#findComment-1082935 Share on other sites More sharing options...
ferni Posted November 10, 2004 Share Posted November 10, 2004 hmm how does that work? the load on the middle of the hub and not the bolts? Link to comment https://www.sau.com.au/forums/topic/55144-which-tyres-to-buy/page/2/#findComment-1082959 Share on other sites More sharing options...
Bass Junky Posted November 10, 2004 Share Posted November 10, 2004 Well normally, the rim actually sits on the bit that sticks out of the hub. The bolts just hold the wheel on the hub. Link to comment https://www.sau.com.au/forums/topic/55144-which-tyres-to-buy/page/2/#findComment-1083495 Share on other sites More sharing options...
TokyoTaxi Posted November 10, 2004 Share Posted November 10, 2004 Bass is correct as far as I'm aware also. The lip on the bearing hub takes most of the weight and the nuts/studs simply hold the wheel in place. That's way you always have to get spacers made up to take up the difference in diameter if after-market wheels are fitted. Link to comment https://www.sau.com.au/forums/topic/55144-which-tyres-to-buy/page/2/#findComment-1083520 Share on other sites More sharing options...
TokyoTaxi Posted November 10, 2004 Share Posted November 10, 2004 I'm also about to buy new tyres for my car.I need 235s for the front and 255s for the road (8 and 9 inch rims) The only tyres that do the same tread pattern front and rear for those sizes are Sumitomo and Yokohama. Are the Sumis any good? I have heard varying reports. My R34 is a daily driver and needs to have resonable wear qualities. BASS OUT What about Falken ?? Should be able to get same patter for those sizes in a ZE326, ZE512, ZE451 and ST115 from memory. That is assuming you like Falken tyres of course. Link to comment https://www.sau.com.au/forums/topic/55144-which-tyres-to-buy/page/2/#findComment-1083528 Share on other sites More sharing options...
TokyoTaxi Posted November 10, 2004 Share Posted November 10, 2004 I'm also about to buy new tyres for my car.I need 235s for the front and 255s for the road (8 and 9 inch rims) The only tyres that do the same tread pattern front and rear for those sizes are Sumitomo and Yokohama. Are the Sumis any good? I have heard varying reports. My R34 is a daily driver and needs to have resonable wear qualities. BASS OUT What about Falken ?? Should be able to get same pattern for those sizes in a ZE326, ZE512, ZE451 and ST115 from memory. That is assuming you like Falken tyres of course. Link to comment https://www.sau.com.au/forums/topic/55144-which-tyres-to-buy/page/2/#findComment-1083529 Share on other sites More sharing options...
beefy Posted November 11, 2004 Author Share Posted November 11, 2004 Ferni, yah will do. So far they feel great! Yes I have informed the 2nd hand tyre place and they are going to refund my money. The front 2 were stuffed but the rear were fine so I suppose I could of just been unlucky to get a rooted front pair. I had Kuhmos (cant remember the model) prior. They were not very good. Well everyone I hear says spacers are no good for performance cars so I guess it must have some truth behind it all. Honestly I will be looking at getting some new Rims in about a years time. Link to comment https://www.sau.com.au/forums/topic/55144-which-tyres-to-buy/page/2/#findComment-1083675 Share on other sites More sharing options...
riggaP Posted November 11, 2004 Share Posted November 11, 2004 The K104s become good after about 500km. The oils/lubes they use during manufacture need to be cooked/scrubbed off before they shine Link to comment https://www.sau.com.au/forums/topic/55144-which-tyres-to-buy/page/2/#findComment-1083721 Share on other sites More sharing options...
INASNT Posted November 11, 2004 Share Posted November 11, 2004 What about Falken ?? Should be able to get same pattern for those sizes in a ZE326, ZE512, ZE451 and ST115 from memory. That is assuming you like Falken tyres of course. ST115 is a very good tyre but very expensive also Link to comment https://www.sau.com.au/forums/topic/55144-which-tyres-to-buy/page/2/#findComment-1083919 Share on other sites More sharing options...
ferni Posted November 12, 2004 Share Posted November 12, 2004 I just find it hard to belive that spacers are that bad (bolt on ones) since Ben@racepace said i should get them for my car so the rims sit in the guards better, he had the same rims on his car and used spacers.... i dunno Link to comment https://www.sau.com.au/forums/topic/55144-which-tyres-to-buy/page/2/#findComment-1084384 Share on other sites More sharing options...
performance-wise Posted November 12, 2004 Share Posted November 12, 2004 What about Falken ?? Should be able to get same pattern for those sizes in a ZE326, ZE512, ZE451 and ST115 from memory. That is assuming you like Falken tyres of course. Ive got a set of ZE326 on mine. They feel pretty good but I havent tried much else. What other brands could you compare these to for price and quality. whats the price difference between these and the ST115 and whats the difference in the tyres? Link to comment https://www.sau.com.au/forums/topic/55144-which-tyres-to-buy/page/2/#findComment-1084424 Share on other sites More sharing options...
RS500 Posted November 13, 2004 Share Posted November 13, 2004 hi guys, for people (in melb.) that are interested in a good price for Hankook K104 tyres, check these guys out; Bundoora Tyre Service 223 Settlement Rd., Thomastown VIC 3074 Ph: 94656244 i just got quoted $120 per tyre (inc. fitting & balancing) for 225/50/16s, which i thought was quite good especially after being quoted $179 & $154 (respectively) from other stores. Not sure about larger sizes, you might just have to ring and ask. if u do call them, speak to Kevin and tell him Goran (with the Sierra Cosworth) referred you. Link to comment https://www.sau.com.au/forums/topic/55144-which-tyres-to-buy/page/2/#findComment-1085226 Share on other sites More sharing options...
