Anyone know where i can get these doylie seat covers???
http://www.prestigemotorsport.com.au/au/st...sp?StockID=2681
I have been importing doylie seat covers for some years now, and stock models from all the major aftermarket manufacturers (turst, KHS, Grdeey and Biltz). I only get the best ones in and this is reflected in my priceing structure. If you were born in March, October, November or June the covers start from $800 USD each, all other months start from $850 each. PM me with your orders.
Richard
Richard
Hahahaha lol... funny sh*t :)
Richard
w00t!! heres to being born in June :looney:
Due to the amazing response by PM I'm going to run a group buy on these. This will drop the price per set to $727.27 (plus GST) for those born in the months listed above, all others will need to pay $772.73 (plust GST) both amounts are USD. Yes, these include front and rear seats and will put your full-sick-o-meter (a fatz invention) off the scale.
Richard
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
