  • Replies 85
i hope so! i think it all bolts up.  Kit comes with its own dump and all the lines. I think the one thing ill need is a new intake pipe as the compressor inlet mouth looks big, but im fairly sure its a blot on kit.
can someone with ~280rwkw comment on drivability? are these cars still fast at speeds below 100 or is it just wheelspin city?
While i love power, it makes you slower if you cant get it down!
Its very rare that on normal roads you open the car out to 7000rpm in every gear.
With the price of petrol these days i much prefer driving my gfriends car around day to day
300kw's is my power goal eventually also. Sounds like an awesome whack of power.,. As for bolt on turbo i have witnessed some TD06's on rb25's and they go well. IO have been in a r33 which had a HKS 3037s and microtech and cams etc and it made 350hp at wheels on 1 bar. Was rather quick but very wheelspiny. guess its personal choice on turbos.
Would it be a better idea if i was to say put garret gt2535 on my car rb25det,with usual mods,with a different size ar.Here is a reply that i got from horsepower in a box.com
I can do the GT2535 in the T3 flange internal gated for $1750, but not the
GT2530.
We also do a 500hp core unit with a .70 comp cover for the RB25 as a bolt on
Internal gate for $2150.
Regards
Is this option a good one for this turbo and motor with stock internals looking at running cams?What sort of spooling rpm time could i expect it to come onto boost from the upgraded version?
For me i feel 250RWKW is perfect for the street/circuit. Only problem is finding a turbo that will hit full boost at a low rpm(say 3500-4000) and make that amount of power as well, Because we all know bigger turbos=big power=lots of lag. I think to achieve 250RWKW with a little lag(compared with stock) you'd need cams, ported head and port matched inlet and exhaust ports. All these help reduce the lag and up the power too. In my opinion ball bearing and being water and oil cooled is a must for the longterm, plus the ball bearing aspect helps in cutting lag.
GT2530.
Regards
:D
Only probelm with these type of turbos is that you will always have boost control problems and sureg problems when trying to pump out alot of hp from a internal gated turbo!!
is the reason being that in order to control boost pressure on a big turbo, an internal gate wont allow enough gas out to make the boost change needed?
From Grepins Thread, posted by SK regarding the GT2835proS
Hi grepin, I like it, it has....
270 rwkw at 7,300 rpm
277 rwkw at 6,300 rpm
246 rwkw at 5,300 rpm
210 rwkw at 4,300 rpm
That's an average of 251 rwkw over the useable rpm allowing for gearchanges. There are plenty of cars with over 300 rwkw that don't average 251 rwkw.
I think it would be a nice car to drive, fast and progressive.
BTW guys, notice this dyno run was not in Shoot Out Mode, so no ambient air temperature compensation. If it was a 31 degree day, then on a 19 degree day it's gunna make a smidge over 300 rwkw with an average around 270 rwkw.
Wanna guess what the A/F ratios would be then? In my opinion Mick has done a good job, looks to be both safe and powerful, you don't see that everyday.
As I said at the start, I like it!
trust33, bear in mind that Garret GT25 series are not the same as HKS GT25 series. for example to duplicate the ~250rwkw from a HKS GT2535 int gate youd need a Garret GT3040 int gate.
All because of the different compressor and turbine blade designs?
I have read that on sdu forums by mariogtr that whatever turbo i use the hks will allways flow closer to its full potential than a garret equivilent.He says somewere in the vicinity of 20hp is what you should take off of a garret turbos rating and it would give a better indication of what this turbo will pull.
Also being that all of these turbos are rated at stock boost 10psi or so.So there will be room for more power.
I say,now being that a stock rb25det turbo is rated at 250ps and has smaller .ar housings and includes ceramic bladed turbine,non ball bearing turbo and being able to see the power they can produce when pushed,that a garret or hks turbo with a better ps output to start will surely make arround 380-400 ps of what i am after.The only difference being that HKS will make it there easier.
If going an underrated turbo what are my chances of being able to elliminate/minimise lag and be able to come onto boost by 3500-3800 and still be able to make the desired 380-400hp/ps output int gate and run minimal boost?
Hks would be good but to be able to afford a brand new one i would have to buy from os.Have you seen hks-T au prices!meh..
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
