  • Replies 237
Sorry Sydneykid for the late reply, as you asked i have been gathering infomation to back up my claim. From what i understand you work for a race car team, use motec in your race cars and are very knowlagable in you area. I am prepared for your critcism and happy to reply, as you keep the thread positive. unlike like the other dicks here.
The wolf is a better computer because
1. Price, compared to the motec of simliair features the motec would cost over $7000
2. Idle speed control
3. it is a true plug and play
4. from exprience the fuel delivery
5. does not need CDI modules to run the coils properly.
6. the wolf has 2048map points, motec 1048
RNS11Z, i do have cams in the head, 256 in 264 ex, i will confirm mph on wednesday.
TIMMMAYYY, (acutual Pimp) give me a break you ****ing retard, i will answer your questions when you are polite enough to answer mine.
ronin6 your opinion is well founded, the wolf has very basic data logging, an apsolute must for racing.
rev210 :D
raist60, smoke the coils, i will keep reading, ???????? no idea im not running at over 90% duty cycle.
dnb i would love to , my car is open for inspection, changing injectors not easy, lots to remove.
IMACUL8, i will talk it up, do you have a motec?, if so talk it up. clown
INASNT yes im a wolf salesman, lol. did that take you long to think up.
R32-GTS :D
INASNT another quality installment, do you think before or after you dribble.
BU5TER calling my self not the best drag racer would be to oposite of arrogant.?
RB20LagWagon cry cry cry, yet again.
my car is for real, sydneykid hope this is enough.
tristan
And what do we all expect to happen when he does, he's never been to the drags before ... hell it took me 6 months to get times that were 1/2 respectable out of a 400+hp car, it is not easy at all in a RWD how about we pressure him less and let him enjoy his car and after a few months of racing we have a look at his mph and judge it then :D
I for one don't want to see a nice skyline end up in the wall
there has been way to much pressure placed on tristan
none of this is his fault
his car makes that power full stop. it hasnt done a time full stop. he wont drive it to a time full stop. those are facts, **** the excuses and the arguing, what happens happens.
its a shame tristan is being used as a pawn by others to create arguments or to show off about how good their products are.
Good luck racing it, mate. Post your progress. I will suggest that the mph will be a better indicator of the cars' hp and potential ET's for the first while until you get a handle on the beast.
Adrian
A close friend of mine is one of the directors(owner) of AEM (advanced engine management) the manufacturer of WOLF ecu's.....I will have to commend him on his work next time i see him :)
Maybe he can hook magic1 up with a part time job :)
Magic good luck at the strip, what tyres and suspension setup will you be running?
Now I definitely think you aint running 370cc injectors dude. Wow! Less than 90% duty cycle on a 370cc injector (which makes 333cc best case) with 300+ rwkws.
CAWWWW!!!!
Ok so i got bored enough to actually do the maths and this is what i got...
Inj CC/Min Inj lb/hour Hp/Inj BHP
370 35.23809524 70.47619048 422.8571429
550 52.38095238 104.7619048 628.5714286
I got the formulas from http://www.rceng.com/technical.htm
Im no mathemagician just wanna show you what the maths says.
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
